UHD  003.003.002
Public Types | Public Member Functions | List of all members
uhd::usrp::mboard_iface Class Referenceabstract
#include <mboard_iface.hpp>
Inheritance diagram for uhd::usrp::mboard_iface:
uhd::i2c_iface uhd::spi_iface uhd::uart_iface
typedef boost::shared_ptr< mboard_ifacesptr
- Public Types inherited from uhd::i2c_iface
- Public Types inherited from uhd::spi_iface
typedef boost::shared_ptr< spi_ifacesptr
- Public Types inherited from uhd::uart_iface
typedef boost::shared_ptr< uart_ifacesptr
virtual void poke32 (boost::uint32_t addr, boost::uint32_t data)=0
virtual boost::uint32_t peek32 (boost::uint32_t addr)=0
virtual void poke16 (boost::uint32_t addr, boost::uint16_t data)=0
virtual boost::uint16_t peek16 (boost::uint32_t addr)=0
- Public Member Functions inherited from uhd::i2c_iface
virtual void write_i2c (boost::uint8_t addr, const byte_vector_t &buf)=0
virtual byte_vector_t read_i2c (boost::uint8_t addr, size_t num_bytes)=0
virtual void write_eeprom (boost::uint8_t addr, boost::uint8_t offset, const byte_vector_t &buf)
virtual byte_vector_t read_eeprom (boost::uint8_t addr, boost::uint8_t offset, size_t num_bytes)
- Public Member Functions inherited from uhd::spi_iface
virtual boost::uint32_t transact_spi (int which_slave, const spi_config_t &config, boost::uint32_t data, size_t num_bits, bool readback)=0
virtual boost::uint32_t read_spi (int which_slave, const spi_config_t &config, boost::uint32_t data, size_t num_bits)
virtual void write_spi (int which_slave, const spi_config_t &config, boost::uint32_t data, size_t num_bits)
- Public Member Functions inherited from uhd::uart_iface
virtual void write_uart (const std::string &buf)=0
virtual std::string read_uart (double timeout)=0
The mboard interface class: Provides a set of functions to implementation layer. Including spi, peek, poke, control...
typedef boost::shared_ptr<mboard_iface> uhd::usrp::mboard_iface::sptr
◆ peek16()
virtual boost::uint16_t uhd::usrp::mboard_iface::peek16 ( boost::uint32_t  addr)
Read a register (16 bits)
addrthe address
the 16bit data
◆ peek32()
virtual boost::uint32_t uhd::usrp::mboard_iface::peek32 ( boost::uint32_t  addr)
Read a register (32 bits)
addrthe address
the 32bit data
◆ poke16()
virtual void uhd::usrp::mboard_iface::poke16 ( boost::uint32_t  addr,
Write a register (16 bits)
addrthe address
datathe 16bit data
◆ poke32()
virtual void uhd::usrp::mboard_iface::poke32 ( boost::uint32_t  addr,
Write a register (32 bits)
addrthe address
datathe 32bit data
