UHD  003.004.000-0-gd97b9dee
#include <udp_simple.hpp>
◆ get_recv_addr()
◆ make_broadcast()
const std::string &  port
◆ make_connected()
◆ make_uart()
udpthe UDP transport object
a new UART interface
◆ recv()
double  timeout = 0.1
timeoutthe timeout in seconds
◆ send()
buffsingle asio buffer
the number of bytes sent
◆ mtu
