003.004.000-0-gd97b9dee
#include <stream.hpp>
| stream_args_t (const std::string &cpu="", const std::string &otw="") | |
| Convenience constructor for streamer args. More... | |
Public Attributes | |
| std::string | cpu_format |
| std::string | otw_format |
| device_addr_t | args |
| std::vector< size_t > | channels |
inline |
| device_addr_t uhd::stream_args_t::args |
| std::vector<size_t> uhd::stream_args_t::channels |
The channels is a list of channel numbers. Leave this blank to default to channel 0. Set channels for a multi-channel application. Channel mapping depends on the front-end selection.
| std::string uhd::stream_args_t::cpu_format |
| std::string uhd::stream_args_t::otw_format |
1.8.13
