003.004.001-0-g3fb06756
#include <metadata.hpp>
Public Types | |
| enum | error_code_t { ERROR_CODE_NONE = 0x0, ERROR_CODE_TIMEOUT = 0x1, ERROR_CODE_LATE_COMMAND = 0x2, ERROR_CODE_BROKEN_CHAIN = 0x4, ERROR_CODE_OVERFLOW = 0x8, ERROR_CODE_ALIGNMENT = 0xc, ERROR_CODE_BAD_PACKET = 0xf } |
Public Attributes | |
| bool | has_time_spec |
| Has time specification? More... | |
| time_spec_t | time_spec |
| Time of the first sample. More... | |
| bool | more_fragments |
| size_t | fragment_offset |
| bool | start_of_burst |
| Start of burst will be true for the first packet in the chain. More... | |
| bool | end_of_burst |
| End of burst will be true for the last packet in the chain. More... | |
| enum uhd::rx_metadata_t::error_code_t | error_code |
| bool uhd::rx_metadata_t::end_of_burst |
| enum uhd::rx_metadata_t::error_code_t uhd::rx_metadata_t::error_code |
| size_t uhd::rx_metadata_t::fragment_offset |
| bool uhd::rx_metadata_t::has_time_spec |
| bool uhd::rx_metadata_t::more_fragments |
| bool uhd::rx_metadata_t::start_of_burst |
| time_spec_t uhd::rx_metadata_t::time_spec |
1.8.13
