UHD  003.004.002-0-g7f44d838
Public Types | Public Member Functions | Static Public Member Functions | List of all members
uhd::gain_group Class Referenceabstract
#include <gain_group.hpp>
Inheritance diagram for uhd::gain_group:
typedef boost::shared_ptr< gain_groupsptr
virtual gain_range_t get_range (const std::string &name="")=0
virtual double get_value (const std::string &name="")=0
virtual void set_value (double gain, const std::string &name="")=0
virtual const std::vector< std::string > get_names (void)=0
virtual void register_fcns (const std::string &name, const gain_fcns_t &gain_fcns, size_t priority=0)=0
static sptr make (void)
typedef boost::shared_ptr<gain_group> uhd::gain_group::sptr
◆ get_names()
virtual const std::vector<std::string> uhd::gain_group::get_names ( void  )
Get a list of names of registered gain elements. The names are in the order that they were registered.
a vector of gain name strings
◆ get_range()
virtual gain_range_t uhd::gain_group::get_range ( const std::string &  name = "")
Get the gain range for the gain element specified by name. For an empty name, get the overall gain range for this group. Overall step is defined as the minimum step size.
namename of the gain element (optional)
a gain range with overall min, max, step
◆ get_value()
virtual double uhd::gain_group::get_value ( const std::string &  name = "")
Get the gain value for the gain element specified by name. For an empty name, get the overall gain value for this group.
a gain value of the element or all elements
◆ make()
static sptr uhd::gain_group::make ( void  )
Make a new empty gain group.
a gain group object.
◆ register_fcns()
virtual void uhd::gain_group::register_fcns ( const std::string &  name,
const gain_fcns_t gain_fcns,
size_t  priority = 0
Register a set of gain functions into this group:
The name should be a unique and non-empty name. Othwerwise, the implementation will rename it.
Priority determines how power will be distributed with higher priorities getting the power first, and lower priorities getting the remainder power.
gain_fcnsthe set of gain functions
prioritythe priority of the gain element
◆ set_value()
virtual void uhd::gain_group::set_value ( double  gain,
Set the gain value for the gain element specified by name. For an empty name, set the overall gain value for this group. The power will be distributed across individual gain elements. The semantics of how to do this are determined by the priority.
gainthe gain to set for the lement or across the group
