003.004.002-0-g7f44d838
#include <dboard_iface.hpp>
Public Types | |
| enum | unit_t { UNIT_RX = int('r'), UNIT_TX = int('t') } |
| tells the host which unit to use More... | |
| enum | atr_reg_t { ATR_REG_IDLE = int('i'), ATR_REG_TX_ONLY = int('t'), ATR_REG_RX_ONLY = int('r'), ATR_REG_FULL_DUPLEX = int('f') } |
| possible atr registers More... | |
| enum | aux_dac_t { AUX_DAC_A = int('a'), AUX_DAC_B = int('b'), AUX_DAC_C = int('c'), AUX_DAC_D = int('d') } |
| aux dac selection enums (per unit) More... | |
| enum | aux_adc_t { AUX_ADC_A = int('a'), AUX_ADC_B = int('b') } |
| aux adc selection enums (per unit) More... | |
| typedef boost::shared_ptr< dboard_iface > | sptr |
| typedef dboard_iface_special_props_t | special_props_t |
Public Types inherited from uhd::i2c_iface | |
| typedef boost::shared_ptr< i2c_iface > | sptr |
| virtual special_props_t | get_special_props (void)=0 |
| virtual void | write_aux_dac (unit_t unit, aux_dac_t which_dac, double value)=0 |
| virtual double | read_aux_adc (unit_t unit, aux_adc_t which_adc)=0 |
| virtual void | set_pin_ctrl (unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) |
| virtual boost::uint16_t | get_pin_ctrl (unit_t unit) |
| virtual void | set_atr_reg (unit_t unit, atr_reg_t reg, boost::uint16_t value, boost::uint16_t mask=0xffff) |
| virtual boost::uint16_t | get_atr_reg (unit_t unit, atr_reg_t reg) |
| virtual void | set_gpio_ddr (unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) |
| virtual boost::uint16_t | get_gpio_ddr (unit_t unit) |
| virtual void | set_gpio_out (unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff) |
| virtual boost::uint16_t | get_gpio_out (unit_t unit) |
| virtual void | set_gpio_debug (unit_t unit, int which)=0 |
| virtual boost::uint16_t | read_gpio (unit_t unit)=0 |
| virtual void | write_spi (unit_t unit, const spi_config_t &config, boost::uint32_t data, size_t num_bits)=0 |
| virtual boost::uint32_t | read_write_spi (unit_t unit, const spi_config_t &config, boost::uint32_t data, size_t num_bits)=0 |
| virtual void | set_clock_rate (unit_t unit, double rate)=0 |
| virtual double | get_clock_rate (unit_t unit)=0 |
| virtual std::vector< double > | get_clock_rates (unit_t unit)=0 |
| virtual void | set_clock_enabled (unit_t unit, bool enb)=0 |
| virtual double | get_codec_rate (unit_t unit)=0 |
Public Member Functions inherited from uhd::i2c_iface | |
| virtual void | write_i2c (boost::uint8_t addr, const byte_vector_t &buf)=0 |
| virtual byte_vector_t | read_i2c (boost::uint8_t addr, size_t num_bytes)=0 |
| virtual void | write_eeprom (boost::uint8_t addr, boost::uint8_t offset, const byte_vector_t &buf) |
| virtual byte_vector_t | read_eeprom (boost::uint8_t addr, boost::uint8_t offset, size_t num_bytes) |
Protected Member Functions | |
| dboard_iface (void) | |
| typedef boost::shared_ptr<dboard_iface> uhd::usrp::dboard_iface::sptr |
protected |
| unit | which unit rx or tx |
| reg | which ATR register |
virtual |
virtual |
virtual |
Read from an aux adc.
| which_adc | the adc index 0, 1, 2, 3... |
| unit | which unit, rx or tx |
| config | configuration settings |
| data | the bits to write MSB first |
| num_bits | the number of bits in data |
virtual |
| value | 16-bits, 0=ATR output low, 1=ATR output high |
| mask | 16-bits, 0=do not change, 1=change value |
| enb | true for enabled |
| rate | the clock rate in Hz |
virtual |
| value | 16-bits, 0=GPIO input, 1=GPIO output |
Setup the GPIO debug mux.
| which | which debug: 0, 1 |
virtual |
| value | 16-bits, 0=GPIO output low, 1=GPIO output high |
virtual |
| value | 16-bits, 0=GPIO controlled, 1=ATR controlled |
Write to an aux dac.
| which_dac | the dac index 0, 1, 2, 3... |
| value | the value in volts |
1.8.13
