UHD  003.004.003-0-g461eb1c7
uhd::range_t Class Reference
#include <ranges.hpp>
 range_t (double value=0)
 range_t (double start, double stop, double step=0)
double start (void) const
 Get the start value for this range. More...
double stop (void) const
 Get the stop value for this range. More...
double step (void) const
 Get the step value for this range. More...
const std::string to_pp_string (void) const
 Convert this range to a printable string. More...
A range object describes a set of discrete values of the form: y = start + step*n, where n is an integer between 0 and (stop - start)/step
◆ range_t() [1/2]
uhd::range_t::range_t ( double  value = 0)
Create a range from a single value. The step size will be taken as zero.
valuethe only possible value in this range
◆ range_t() [2/2]
uhd::range_t::range_t ( double  start,
double  stop,
double  step = 0
Create a range from a full set of values. A step size of zero implies infinite precision.
startthe minimum value for this range
stopthe maximum value for this range
stepthe step size for this range
◆ start()
double uhd::range_t::start ( void  ) const
◆ step()
double uhd::range_t::step ( void  ) const
◆ stop()
double uhd::range_t::stop ( void  ) const
◆ to_pp_string()
const std::string uhd::range_t::to_pp_string ( void  ) const
