003.004.003-0-g461eb1c7
#include <serial.hpp>
Public Types | |
| typedef boost::shared_ptr< spi_iface > | sptr |
| virtual boost::uint32_t | transact_spi (int which_slave, const spi_config_t &config, boost::uint32_t data, size_t num_bits, bool readback)=0 |
| virtual boost::uint32_t | read_spi (int which_slave, const spi_config_t &config, boost::uint32_t data, size_t num_bits) |
| virtual void | write_spi (int which_slave, const spi_config_t &config, boost::uint32_t data, size_t num_bits) |
| typedef boost::shared_ptr<spi_iface> uhd::spi_iface::sptr |
virtual |
Read from the SPI bus.
| which_slave | the slave device number |
| config | spi config args |
| data | the bits to write out (be sure to set write bit) |
| num_bits | how many bits in data |
Perform a spi transaction.
| data | the bits to write |
| readback | true to readback a value |
virtual |
Write to the SPI bus.
1.8.13
