UHD  003.004.003-0-g461eb1c7
uhd::usrp::dboard_iface Class Referenceabstract
#include <dboard_iface.hpp>
Inheritance diagram for uhd::usrp::dboard_iface:
uhd::i2c_iface
enum  unit_t { UNIT_RX = int('r'), UNIT_TX = int('t') }
 tells the host which unit to use More...
enum  atr_reg_t { ATR_REG_IDLE = int('i'), ATR_REG_TX_ONLY = int('t'), ATR_REG_RX_ONLY = int('r'), ATR_REG_FULL_DUPLEX = int('f') }
 possible atr registers More...
enum  aux_dac_t { AUX_DAC_A = int('a'), AUX_DAC_B = int('b'), AUX_DAC_C = int('c'), AUX_DAC_D = int('d') }
 aux dac selection enums (per unit) More...
enum  aux_adc_t { AUX_ADC_A = int('a'), AUX_ADC_B = int('b') }
 aux adc selection enums (per unit) More...
typedef boost::shared_ptr< dboard_ifacesptr
typedef dboard_iface_special_props_t special_props_t
- Public Types inherited from uhd::i2c_iface
virtual special_props_t get_special_props (void)=0
virtual void write_aux_dac (unit_t unit, aux_dac_t which_dac, double value)=0
virtual double read_aux_adc (unit_t unit, aux_adc_t which_adc)=0
virtual void set_pin_ctrl (unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff)
virtual boost::uint16_t get_pin_ctrl (unit_t unit)
virtual void set_atr_reg (unit_t unit, atr_reg_t reg, boost::uint16_t value, boost::uint16_t mask=0xffff)
virtual boost::uint16_t get_atr_reg (unit_t unit, atr_reg_t reg)
virtual void set_gpio_ddr (unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff)
virtual boost::uint16_t get_gpio_ddr (unit_t unit)
virtual void set_gpio_out (unit_t unit, boost::uint16_t value, boost::uint16_t mask=0xffff)
virtual boost::uint16_t get_gpio_out (unit_t unit)
virtual void set_gpio_debug (unit_t unit, int which)=0
virtual boost::uint16_t read_gpio (unit_t unit)=0
virtual void write_spi (unit_t unit, const spi_config_t &config, boost::uint32_t data, size_t num_bits)=0
virtual boost::uint32_t read_write_spi (unit_t unit, const spi_config_t &config, boost::uint32_t data, size_t num_bits)=0
virtual void set_clock_rate (unit_t unit, double rate)=0
virtual double get_clock_rate (unit_t unit)=0
virtual std::vector< double > get_clock_rates (unit_t unit)=0
virtual void set_clock_enabled (unit_t unit, bool enb)=0
virtual double get_codec_rate (unit_t unit)=0
- Public Member Functions inherited from uhd::i2c_iface
virtual void write_i2c (boost::uint8_t addr, const byte_vector_t &buf)=0
virtual byte_vector_t read_i2c (boost::uint8_t addr, size_t num_bytes)=0
virtual void write_eeprom (boost::uint8_t addr, boost::uint8_t offset, const byte_vector_t &buf)
virtual byte_vector_t read_eeprom (boost::uint8_t addr, boost::uint8_t offset, size_t num_bytes)
 dboard_iface (void)
◆ special_props_t
typedef boost::shared_ptr<dboard_iface> uhd::usrp::dboard_iface::sptr
◆ atr_reg_t
Enumerator
ATR_REG_IDLE
ATR_REG_TX_ONLY
ATR_REG_RX_ONLY
ATR_REG_FULL_DUPLEX
◆ aux_adc_t
Enumerator
AUX_ADC_A
AUX_ADC_B
◆ aux_dac_t
Enumerator
AUX_DAC_A
AUX_DAC_B
AUX_DAC_C
AUX_DAC_D
◆ unit_t
Enumerator
UNIT_RX
UNIT_TX
◆ dboard_iface()
uhd::usrp::dboard_iface::dboard_iface ( void  )
◆ get_atr_reg()
virtual boost::uint16_t uhd::usrp::dboard_iface::get_atr_reg ( unit_t  unit,
atr_reg_t  reg
virtual
unitwhich unit rx or tx
regwhich ATR register
the 16-bit settings value
◆ get_clock_rate()
virtual double uhd::usrp::dboard_iface::get_clock_rate ( unit_t  unit)
the clock rate in Hz
◆ get_clock_rates()
virtual std::vector<double> uhd::usrp::dboard_iface::get_clock_rates ( unit_t  unit)
a list of clock rates in Hz
◆ get_codec_rate()
virtual double uhd::usrp::dboard_iface::get_codec_rate ( unit_t  unit)
the codec rate in Hz
◆ get_gpio_ddr()
virtual boost::uint16_t uhd::usrp::dboard_iface::get_gpio_ddr ( unit_t  unit)
virtual
◆ get_gpio_out()
virtual boost::uint16_t uhd::usrp::dboard_iface::get_gpio_out ( unit_t  unit)
virtual
◆ get_pin_ctrl()
virtual boost::uint16_t uhd::usrp::dboard_iface::get_pin_ctrl ( unit_t  unit)
virtual
◆ get_special_props()
virtual special_props_t uhd::usrp::dboard_iface::get_special_props ( void  )
the special properties struct
◆ read_aux_adc()
virtual double uhd::usrp::dboard_iface::read_aux_adc ( unit_t  unit,
aux_adc_t  which_adc
Read from an aux adc.
which_adcthe adc index 0, 1, 2, 3...
the value in volts
◆ read_gpio()
virtual boost::uint16_t uhd::usrp::dboard_iface::read_gpio ( unit_t  unit)
the value of the gpio unit
◆ read_write_spi()
virtual boost::uint32_t uhd::usrp::dboard_iface::read_write_spi ( unit_t  unit,
const spi_config_t config,
size_t  num_bits
unitwhich unit, rx or tx
configconfiguration settings
datathe bits to write MSB first
num_bitsthe number of bits in data
the data that was read
◆ set_atr_reg()
virtual void uhd::usrp::dboard_iface::set_atr_reg ( unit_t  unit,
atr_reg_t  reg,
boost::uint16_t  mask = 0xffff
virtual
value16-bits, 0=ATR output low, 1=ATR output high
mask16-bits, 0=do not change, 1=change value
◆ set_clock_enabled()
virtual void uhd::usrp::dboard_iface::set_clock_enabled ( unit_t  unit,
bool  enb
enbtrue for enabled
◆ set_clock_rate()
virtual void uhd::usrp::dboard_iface::set_clock_rate ( unit_t  unit,
double  rate
ratethe clock rate in Hz
◆ set_gpio_ddr()
virtual void uhd::usrp::dboard_iface::set_gpio_ddr ( unit_t  unit,
virtual
value16-bits, 0=GPIO input, 1=GPIO output
◆ set_gpio_debug()
virtual void uhd::usrp::dboard_iface::set_gpio_debug ( unit_t  unit,
int  which
Setup the GPIO debug mux.
whichwhich debug: 0, 1
◆ set_gpio_out()
virtual void uhd::usrp::dboard_iface::set_gpio_out ( unit_t  unit,
virtual
value16-bits, 0=GPIO output low, 1=GPIO output high
◆ set_pin_ctrl()
virtual void uhd::usrp::dboard_iface::set_pin_ctrl ( unit_t  unit,
virtual
value16-bits, 0=GPIO controlled, 1=ATR controlled
◆ write_aux_dac()
virtual void uhd::usrp::dboard_iface::write_aux_dac ( unit_t  unit,
double  value
Write to an aux dac.
which_dacthe dac index 0, 1, 2, 3...
valuethe value in volts
◆ write_spi()
virtual void uhd::usrp::dboard_iface::write_spi ( unit_t  unit,
size_t  num_bits
