UHD  003.004.003-0-g461eb1c7
Public Types | Public Attributes | List of all members
uhd::rx_metadata_t Struct Reference
#include <metadata.hpp>
enum  error_code_t {
  ERROR_CODE_NONE = 0x0, ERROR_CODE_TIMEOUT = 0x1, ERROR_CODE_LATE_COMMAND = 0x2, ERROR_CODE_BROKEN_CHAIN = 0x4,
  ERROR_CODE_OVERFLOW = 0x8, ERROR_CODE_ALIGNMENT = 0xc, ERROR_CODE_BAD_PACKET = 0xf
Public Attributes
bool has_time_spec
 Has time specification? More...
time_spec_t time_spec
 Time of the first sample. More...
bool more_fragments
size_t fragment_offset
bool start_of_burst
 Start of burst will be true for the first packet in the chain. More...
bool end_of_burst
 End of burst will be true for the last packet in the chain. More...
enum uhd::rx_metadata_t::error_code_t error_code
◆ error_code_t
  • none
  • late command
  • broken chain
  • overflow
Enumerator
ERROR_CODE_NONE
No error associated with this metadata.
ERROR_CODE_TIMEOUT
No packet received, implementation timed-out.
A stream command was issued in the past.
Expected another stream command.
ERROR_CODE_OVERFLOW
An internal receive buffer has filled.
Multi-channel alignment failed.
The packet could not be parsed.
◆ end_of_burst
bool uhd::rx_metadata_t::end_of_burst
◆ error_code
enum uhd::rx_metadata_t::error_code_t uhd::rx_metadata_t::error_code
◆ fragment_offset
size_t uhd::rx_metadata_t::fragment_offset
◆ has_time_spec
bool uhd::rx_metadata_t::has_time_spec
◆ more_fragments
bool uhd::rx_metadata_t::more_fragments
◆ start_of_burst
bool uhd::rx_metadata_t::start_of_burst
◆ time_spec
time_spec_t uhd::rx_metadata_t::time_spec
