003.005.001-0-gf3a16983
#include <ranges.hpp>
| range_t (double value=0) | |
| range_t (double start, double stop, double step=0) | |
| double | start (void) const |
| Get the start value for this range. More... | |
| double | stop (void) const |
| Get the stop value for this range. More... | |
| double | step (void) const |
| Get the step value for this range. More... | |
| const std::string | to_pp_string (void) const |
| Convert this range to a printable string. More... | |
A range object describes a set of discrete values of the form: y = start + step*n, where n is an integer between 0 and (stop - start)/step
| uhd::range_t::range_t | ( | double | value = 0 | ) |
Create a range from a single value. The step size will be taken as zero.
| value | the only possible value in this range |
| uhd::range_t::range_t | ( | double | start, |
| double | stop, | ||
| double | step = 0 |
Create a range from a full set of values. A step size of zero implies infinite precision.
| start | the minimum value for this range |
| stop | the maximum value for this range |
| step | the step size for this range |
| double uhd::range_t::start | ( | void | ) | const |
| double uhd::range_t::step | ( | void | ) | const |
| double uhd::range_t::stop | ( | void | ) | const |
| const std::string uhd::range_t::to_pp_string | ( | void | ) | const |
1.8.13
