003.005.002-0-g0cce80c1
#include <clock_config.hpp>
Public Types | |
| enum | ref_source_t { REF_AUTO = int('a'), REF_INT = int('i'), REF_SMA = int('s'), REF_MIMO = int('m') } |
| enum | pps_source_t { PPS_INT = int('i'), PPS_SMA = int('s'), PPS_MIMO = int('m') } |
| enum | pps_polarity_t { PPS_NEG = int('n'), PPS_POS = int('p') } |
| clock_config_t (void) | |
| static clock_config_t | external (void) |
| A convenience function to create an external clock configuration. More... | |
| static clock_config_t | internal (void) |
| A convenience function to create an internal clock configuration. More... | |
Public Attributes | |
| enum uhd::clock_config_t::ref_source_t | ref_source |
| enum uhd::clock_config_t::pps_source_t | pps_source |
| enum uhd::clock_config_t::pps_polarity_t | pps_polarity |
| uhd::clock_config_t::clock_config_t | ( | void | ) |
| enum uhd::clock_config_t::pps_polarity_t uhd::clock_config_t::pps_polarity |
| enum uhd::clock_config_t::pps_source_t uhd::clock_config_t::pps_source |
| enum uhd::clock_config_t::ref_source_t uhd::clock_config_t::ref_source |
1.8.13
