003.005.003-13-gf4c58120
#include <serial.hpp>
Public Types | |
| typedef boost::shared_ptr< i2c_iface > | sptr |
| virtual void | write_i2c (boost::uint8_t addr, const byte_vector_t &buf)=0 |
| virtual byte_vector_t | read_i2c (boost::uint8_t addr, size_t num_bytes)=0 |
| virtual void | write_eeprom (boost::uint8_t addr, boost::uint8_t offset, const byte_vector_t &buf) |
| virtual byte_vector_t | read_eeprom (boost::uint8_t addr, boost::uint8_t offset, size_t num_bytes) |
| typedef boost::shared_ptr<i2c_iface> uhd::i2c_iface::sptr |
virtual |
Read bytes from an eeprom.
| addr | the address |
| offset | byte offset |
| num_bytes | number of bytes to read |
Read bytes over the i2c.
virtual |
Write bytes to an eeprom.
| buf | the vector of bytes |
Write bytes over the i2c.
1.8.13
