UHD  003.005.005-0-g3c6a906c
Public Types | Public Member Functions | List of all members
#include <stream.hpp>
◆ buffs_type
◆ get_max_num_samps()
◆ get_num_channels()
◆ recv()
rx_metadata_t metadata,
const double  timeout = 0.1,
Receive handles fragmentation as follows: If the buffer has insufficient space to hold all samples that were received in a single packet over-the-wire, then the buffer will be completely filled and the implementation will hold a pointer into the remaining portion of the packet. Subsequent calls will load from the remainder of the packet, and will flag the metadata to show that this is a fragment. The next call to receive, after the remainder becomes exahausted, will perform an over-the-wire receive as usual. See the rx metadata fragment flags and offset fields for details.
