UHD  003.006.000-0-g58f4af97
Public Types | Public Member Functions | List of all members
uhd::tx_streamer Class Referenceabstract
#include <stream.hpp>
Inheritance diagram for uhd::tx_streamer:
typedef boost::shared_ptr< tx_streamersptr
typedef ref_vector< const void * > buffs_type
 Typedef for a pointer to a single, or a collection of send buffers. More...
virtual ~tx_streamer (void)
virtual size_t send (const buffs_type &buffs, const size_t nsamps_per_buff, const tx_metadata_t &metadata, const double timeout=0.1)=0
The TX streamer is the host interface to transmitting samples. It represents the layer between the samples on the host and samples inside the device's transmit DSP processing.
◆ buffs_type
typedef boost::shared_ptr<tx_streamer> uhd::tx_streamer::sptr
◆ ~tx_streamer()
virtual uhd::tx_streamer::~tx_streamer ( void  )
virtual
◆ get_max_num_samps()
virtual size_t uhd::tx_streamer::get_max_num_samps ( void  ) const
◆ get_num_channels()
virtual size_t uhd::tx_streamer::get_num_channels ( void  ) const
◆ recv_async_msg()
virtual bool uhd::tx_streamer::recv_async_msg ( async_metadata_t async_metadata,
double  timeout = 0.1
Receive and asynchronous message from this TX stream.
◆ send()
virtual size_t uhd::tx_streamer::send ( const buffs_type buffs,
const tx_metadata_t metadata,
const double  timeout = 0.1
Send buffers containing samples described by the metadata.
Send handles fragmentation as follows: If the buffer has more items than the maximum per packet, the send method will fragment the samples across several packets. Send will respect the burst flags when fragmenting to ensure that start of burst can only be set on the first fragment and that end of burst can only be set on the final fragment.
This is a blocking call and will not return until the number of samples returned have been read out of each buffer. Under a timeout condition, the number of samples returned may be less than the number of samples specified.
buffsa vector of read-only memory containing samples
nsamps_per_buffthe number of samples to send, per buffer
metadatadata describing the buffer's contents
timeoutthe timeout in seconds to wait on a packet
the number of samples sent
