003.006.000-0-g58f4af97
#include <dboard_manager.hpp>
Public Types | |
| typedef boost::shared_ptr< dboard_manager > | sptr |
| typedef dboard_base::sptr(* | dboard_ctor_t) (dboard_base::ctor_args_t) |
| static void | register_dboard (const dboard_id_t &dboard_id, dboard_ctor_t dboard_ctor, const std::string &name, const std::vector< std::string > &subdev_names=std::vector< std::string >(1, "0")) |
| static void | register_dboard (const dboard_id_t &rx_dboard_id, const dboard_id_t &tx_dboard_id, dboard_ctor_t dboard_ctor, const std::string &name, const std::vector< std::string > &subdev_names=std::vector< std::string >(1, "0")) |
| static sptr | make (dboard_id_t rx_dboard_id, dboard_id_t tx_dboard_id, dboard_id_t gdboard_id, dboard_iface::sptr iface, property_tree::sptr subtree) |
A daughter board subdev dboard_manager class. Create subdev instances for each subdev on a dboard. Provide wax::obj access to the subdevs inside.
| typedef dboard_base::sptr(* uhd::usrp::dboard_manager::dboard_ctor_t) (dboard_base::ctor_args_t) |
| typedef boost::shared_ptr<dboard_manager> uhd::usrp::dboard_manager::sptr |
Make a new dboard manager.
| rx_dboard_id | the id of the rx dboard |
| tx_dboard_id | the id of the tx dboard |
| gdboard_id | the id of the grand-dboard |
| iface | the custom dboard interface |
| subtree | the subtree to load with props |
Register a rx or tx dboard into the system. For single subdevice boards, omit subdev_names.
| dboard_id | the dboard id (rx or tx) |
| dboard_ctor | the dboard constructor function pointer |
| name | the canonical name for the dboard represented |
| subdev_names | the names of the subdevs on this dboard |
Register an xcvr dboard into the system. For single subdevice boards, omit subdev_names.
| rx_dboard_id | the rx unit dboard id |
| tx_dboard_id | the tx unit dboard id |
1.8.13
