UHD  003.006.000-0-g7788c692
Classes | Macros
static.hpp File Reference
#include <uhd/config.hpp>
Classes
struct  _uhd_static_fixture
 Helper for static block, constructor calls function. More...
Macros
#define UHD_SINGLETON_FCN(_t, _x)   static _t &_x(){static _t _x; return _x;}
#define UHD_STATIC_BLOCK(_x)
◆ UHD_SINGLETON_FCN
#define UHD_SINGLETON_FCN (   _t,
  _x
Defines a function that implements the "construct on first use" idiom
_tthe type definition for the instance
_xthe name of the defined function
a reference to the lazy instance
◆ UHD_STATIC_BLOCK
#define UHD_STATIC_BLOCK (   _x)
Value:
void _x(void); \
void _x(void)
Definition: static.hpp:42
Defines a static code block that will be called before main() The static block will catch and print exceptions to std error.
_xthe unique name of the fixture (unique per source)
