003.006.002-0-g09bd61cc
#include <multi_usrp.hpp>
Public Types | |
| typedef boost::shared_ptr< multi_usrp > | sptr |
| virtual device::sptr | get_device (void)=0 |
| rx_streamer::sptr | get_rx_stream (const stream_args_t &args) |
| Convenience method to get a RX streamer. More... | |
| tx_streamer::sptr | get_tx_stream (const stream_args_t &args) |
| Convenience method to get a TX streamer. More... | |
| virtual dict< std::string, std::string > | get_usrp_rx_info (size_t chan=0)=0 |
| virtual dict< std::string, std::string > | get_usrp_tx_info (size_t chan=0)=0 |
| virtual void | set_master_clock_rate (double rate, size_t mboard=ALL_MBOARDS)=0 |
| virtual double | get_master_clock_rate (size_t mboard=0)=0 |
| virtual std::string | get_pp_string (void)=0 |
| virtual std::string | get_mboard_name (size_t mboard=0)=0 |
| virtual time_spec_t | get_time_now (size_t mboard=0)=0 |
| virtual time_spec_t | get_time_last_pps (size_t mboard=0)=0 |
| virtual void | set_time_now (const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_time_next_pps (const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_time_unknown_pps (const time_spec_t &time_spec)=0 |
| virtual bool | get_time_synchronized (void)=0 |
| virtual void | set_command_time (const uhd::time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | clear_command_time (size_t mboard=ALL_MBOARDS)=0 |
| virtual void | issue_stream_cmd (const stream_cmd_t &stream_cmd, size_t chan=ALL_CHANS)=0 |
| virtual void | set_clock_config (const clock_config_t &clock_config, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_time_source (const std::string &source, const size_t mboard=ALL_MBOARDS)=0 |
| virtual std::string | get_time_source (const size_t mboard)=0 |
| virtual std::vector< std::string > | get_time_sources (const size_t mboard)=0 |
| virtual void | set_clock_source (const std::string &source, const size_t mboard=ALL_MBOARDS)=0 |
| virtual std::string | get_clock_source (const size_t mboard)=0 |
| virtual std::vector< std::string > | get_clock_sources (const size_t mboard)=0 |
| virtual size_t | get_num_mboards (void)=0 |
| virtual sensor_value_t | get_mboard_sensor (const std::string &name, size_t mboard=0)=0 |
| virtual std::vector< std::string > | get_mboard_sensor_names (size_t mboard=0)=0 |
| virtual void | set_user_register (const boost::uint8_t addr, const boost::uint32_t data, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_rx_subdev_spec (const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual uhd::usrp::subdev_spec_t | get_rx_subdev_spec (size_t mboard=0)=0 |
| virtual size_t | get_rx_num_channels (void)=0 |
| virtual std::string | get_rx_subdev_name (size_t chan=0)=0 |
| virtual void | set_rx_rate (double rate, size_t chan=ALL_CHANS)=0 |
| virtual double | get_rx_rate (size_t chan=0)=0 |
| virtual meta_range_t | get_rx_rates (size_t chan=0)=0 |
| virtual tune_result_t | set_rx_freq (const tune_request_t &tune_request, size_t chan=0)=0 |
| virtual double | get_rx_freq (size_t chan=0)=0 |
| virtual freq_range_t | get_rx_freq_range (size_t chan=0)=0 |
| virtual freq_range_t | get_fe_rx_freq_range (size_t chan=0)=0 |
| virtual void | set_rx_gain (double gain, const std::string &name, size_t chan=0)=0 |
| void | set_rx_gain (double gain, size_t chan=0) |
| A convenience wrapper for setting overall RX gain. More... | |
| virtual double | get_rx_gain (const std::string &name, size_t chan=0)=0 |
| double | get_rx_gain (size_t chan=0) |
| A convenience wrapper for getting overall RX gain. More... | |
| virtual gain_range_t | get_rx_gain_range (const std::string &name, size_t chan=0)=0 |
| gain_range_t | get_rx_gain_range (size_t chan=0) |
| A convenience wrapper for getting overall RX gain range. More... | |
| virtual std::vector< std::string > | get_rx_gain_names (size_t chan=0)=0 |
| virtual void | set_rx_antenna (const std::string &ant, size_t chan=0)=0 |
| virtual std::string | get_rx_antenna (size_t chan=0)=0 |
| virtual std::vector< std::string > | get_rx_antennas (size_t chan=0)=0 |
| UHD_DEPRECATED bool | get_rx_lo_locked (size_t chan=0) |
| virtual void | set_rx_bandwidth (double bandwidth, size_t chan=0)=0 |
| virtual double | get_rx_bandwidth (size_t chan=0)=0 |
| virtual meta_range_t | get_rx_bandwidth_range (size_t chan=0)=0 |
| UHD_DEPRECATED double | read_rssi (size_t chan=0) |
| virtual dboard_iface::sptr | get_rx_dboard_iface (size_t chan=0)=0 |
| virtual sensor_value_t | get_rx_sensor (const std::string &name, size_t chan=0)=0 |
| virtual std::vector< std::string > | get_rx_sensor_names (size_t chan=0)=0 |
| virtual void | set_rx_dc_offset (const bool enb, size_t chan=ALL_CHANS)=0 |
| virtual void | set_rx_dc_offset (const std::complex< double > &offset, size_t chan=ALL_CHANS)=0 |
| virtual void | set_rx_iq_balance (const std::complex< double > &correction, size_t chan=ALL_CHANS)=0 |
| virtual void | set_tx_subdev_spec (const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual uhd::usrp::subdev_spec_t | get_tx_subdev_spec (size_t mboard=0)=0 |
| virtual size_t | get_tx_num_channels (void)=0 |
| virtual std::string | get_tx_subdev_name (size_t chan=0)=0 |
| virtual void | set_tx_rate (double rate, size_t chan=ALL_CHANS)=0 |
| virtual double | get_tx_rate (size_t chan=0)=0 |
| virtual meta_range_t | get_tx_rates (size_t chan=0)=0 |
| virtual tune_result_t | set_tx_freq (const tune_request_t &tune_request, size_t chan=0)=0 |
| virtual double | get_tx_freq (size_t chan=0)=0 |
| virtual freq_range_t | get_tx_freq_range (size_t chan=0)=0 |
| virtual freq_range_t | get_fe_tx_freq_range (size_t chan=0)=0 |
| virtual void | set_tx_gain (double gain, const std::string &name, size_t chan=0)=0 |
| void | set_tx_gain (double gain, size_t chan=0) |
| A convenience wrapper for setting overall TX gain. More... | |
| virtual double | get_tx_gain (const std::string &name, size_t chan=0)=0 |
| double | get_tx_gain (size_t chan=0) |
| A convenience wrapper for getting overall TX gain. More... | |
| virtual gain_range_t | get_tx_gain_range (const std::string &name, size_t chan=0)=0 |
| gain_range_t | get_tx_gain_range (size_t chan=0) |
| A convenience wrapper for getting overall TX gain range. More... | |
| virtual std::vector< std::string > | get_tx_gain_names (size_t chan=0)=0 |
| virtual void | set_tx_antenna (const std::string &ant, size_t chan=0)=0 |
| virtual std::string | get_tx_antenna (size_t chan=0)=0 |
| virtual std::vector< std::string > | get_tx_antennas (size_t chan=0)=0 |
| UHD_DEPRECATED bool | get_tx_lo_locked (size_t chan=0) |
| virtual void | set_tx_bandwidth (double bandwidth, size_t chan=0)=0 |
| virtual double | get_tx_bandwidth (size_t chan=0)=0 |
| virtual meta_range_t | get_tx_bandwidth_range (size_t chan=0)=0 |
| virtual dboard_iface::sptr | get_tx_dboard_iface (size_t chan=0)=0 |
| virtual sensor_value_t | get_tx_sensor (const std::string &name, size_t chan=0)=0 |
| virtual std::vector< std::string > | get_tx_sensor_names (size_t chan=0)=0 |
| virtual void | set_tx_dc_offset (const std::complex< double > &offset, size_t chan=ALL_CHANS)=0 |
| virtual void | set_tx_iq_balance (const std::complex< double > &correction, size_t chan=ALL_CHANS)=0 |
| static sptr | make (const device_addr_t &dev_addr) |
| static const size_t | ALL_MBOARDS = size_t(~0) |
| A wildcard motherboard index. More... | |
| static const size_t | ALL_CHANS = size_t(~0) |
| A wildcard channel index. More... | |
| static const std::string | ALL_GAINS |
| A wildcard gain element name. More... | |
The Multi-USRP device class:
This class facilitates ease-of-use for most use-case scenarios. The wrapper provides convenience functions to tune the devices, set the dboard gains, antennas, filters, and other properties. This class can be used to interface with a single USRP with one or more channels, or multiple USRPs in a homogeneous setup. All members take an optional parameter for board number or channel number. In the single device, single channel case, these parameters can be unspecified.
When using a single device with multiple channels:
When using multiple devices in a configuration:
Example to setup channel mapping for multiple devices:
//create a multi_usrp with two boards in the configuration device_addr_t dev_addr; dev_addr["addr0"] = "192.168.10.2" dev_addr["addr1"] = "192.168.10.3"; multi_usrp::sptr dev = multi_usrp::make(dev_addr);
//set the board on 10.2 to use the A RX frontend (RX channel 0)
dev->set_rx_subdev_spec("A:A", 0);//set the board on 10.3 to use the B RX frontend (RX channel 1)
dev->set_rx_subdev_spec("A:B", 1);//set both boards to use the AB TX frontend (TX channels 0 and 1)
dev->set_tx_subdev_spec("A:AB", multi_usrp::ALL_MBOARDS);//now that all the channels are mapped, continue with configuration...
| typedef boost::shared_ptr<multi_usrp> uhd::usrp::multi_usrp::sptr |
Clear the command time so future commands are sent ASAP.
| mboard | which motherboard to set the config |
Get the currently set clock source.
| mboard | which motherboard to get the config |
Get a list of possible clock sources.
| mboard | which motherboard to get the list |
Get the underlying device object. This is needed to get access to the streaming API and properties.
Get the center frequency range of the RF frontend.
| chan | the channel index 0 to N-1 |
Get the center frequency range of the TX frontend.
Get the master clock rate.
| mboard | the motherboard index 0 to M-1 |
Get canonical name for this USRP motherboard.
| mboard | which motherboard to query |
Get a motherboard sensor value.
| name | the name of the sensor |
Get a list of possible motherboard sensor names.
Get the number of USRP motherboards in this configuration.
Get the selected RX antenna on the frontend.
Get a list of possible RX antennas on the frontend.
Get the RX bandwidth on the frontend.
Get the range of the possible RX bandwidth settings.
Get the dboard interface object for the RX frontend. The dboard interface gives access to GPIOs, SPI, I2C, low-speed ADC and DAC. Use at your own risk!
Get the RX center frequency.
Get the RX center frequency range. This range includes the overall tunable range of the RX chain, including frontend chain and digital down conversion chain. This tunable limit does not include the baseband bandwidth; users should assume that the actual range is +/- samp_rate/2.
Get the RX gain value for the specified gain element. For an empty name, sum across all gain elements.
| name | the name of the gain element |
inline |
Get the names of the gain elements in the RX chain. Gain elements are ordered from antenna to FPGA.
Get the RX gain range for the specified gain element. For an empty name, calculate the overall gain range.
inline |
inline |
Get the locked status of the LO on the frontend.
Get the number of RX channels in this configuration. This is the number of USRPs times the number of RX channels per board, where the number of RX channels per board is homogeneous among all USRPs.
Gets the RX sample rate.
Get a range of possible RX rates.
Get an RX frontend sensor value.
Get a list of possible RX frontend sensor names.
inline |
Get the name of the RX frontend.
Get the RX frontend specification.
Get the time when the last pps pulse occured.
Get the current time in the usrp time registers.
Get the currently set time source.
Get a list of possible time sources.
Are the times across all motherboards in this configuration synchronized? Checks that all time registers are approximately close but not exact, given that the RTT may varying for a control packet transaction.
Get the selected TX antenna on the frontend.
Get a list of possible TX antennas on the frontend.
Get the TX bandwidth on the frontend.
Get the range of the possible TX bandwidth settings.
Get the dboard interface object for the TX frontend. The dboard interface gives access to GPIOs, SPI, I2C, low-speed ADC and DAC. Use at your own risk!
Get the TX center frequency.
Get the TX center frequency range. This range includes the overall tunable range of the TX chain, including frontend chain and digital up conversion chain. This tunable limit does not include the baseband bandwidth; users should assume that the actual range is +/- samp_rate/2.
Get the TX gain value for the specified gain element. For an empty name, sum across all gain elements.
inline |
Get the names of the gain elements in the TX chain. Gain elements are ordered from antenna to FPGA.
Get the TX gain range for the specified gain element. For an empty name, calculate the overall gain range.
inline |
inline |
Get the number of TX channels in this configuration. This is the number of USRPs times the number of TX channels per board, where the number of TX channels per board is homogeneous among all USRPs.
Gets the TX sample rate.
Get a range of possible TX rates.
Get an TX frontend sensor value.
Get a list of possible TX frontend sensor names.
inline |
Get the name of the TX frontend.
Get the TX frontend specification.
Returns identifying information about this USRP's configuration. Returns motherboard ID, name, and serial. Returns daughterboard RX ID, subdev name and spec, serial, and antenna.
| chan | channel index 0 to N-1 |
Returns identifying information about this USRP's configuration. Returns motherboard ID, name, and serial. Returns daughterboard TX ID, subdev name and spec, serial, and antenna.
| stream_cmd | the stream command to issue |
| dev_addr | the device address |
inline |
Read the RSSI value on the RX frontend.
| exception | if RSSI readback not supported |
Set the clock configuration for the usrp device. DEPRECATED in favor of set time and clock source calls. This tells the usrp how to get a 10Mhz reference and PPS clock. See the documentation for clock_config_t for more info.
| clock_config | the clock configuration to set |
Set the clock source for the usrp device. This sets the source for a 10 Mhz reference clock. Typical options for source: internal, external, MIMO.
| source | a string representing the clock source |
Set the time at which the control commands will take effect.
A timed command will back-pressure all subsequent timed commands, assuming that the subsequent commands occur within the time-window. If the time spec is late, the command will be activated upon arrival.
| time_spec | the time at which the next command will activate |
Set the master clock rate. This controls the rate of the clock that feeds the FPGA DSP. On some devices, this re-tunes the clock to the specified rate. If the specified rate is not available, this method will throw. On other devices, this method notifies the software of the rate, but requires the the user has made the necessary hardware change.
| rate | the new master clock rate in Hz |
Select the RX antenna on the frontend.
| ant | the antenna name |
Set the RX bandwidth on the frontend.
| bandwidth | the bandwidth in Hz |
Enable/disable the automatic RX DC offset correction. The automatic correction subtracts out the long-run average.
When disabled, the averaging option operation is halted. Once halted, the average value will be held constant until the user re-enables the automatic correction or overrides the value by manually setting the offset.
| enb | true to enable automatic DC offset correction |
Set a constant RX DC offset value. The value is complex to control both I and Q. Only set this when automatic correction is disabled.
| offset | the dc offset (1.0 is full-scale) |
Set the RX center frequency.
| tune_request | tune request instructions |
Set the RX gain value for the specified gain element. For an empty name, distribute across all gain elements.
| gain | the gain in dB |
inline |
Set the RX frontend IQ imbalance correction. Use this to adjust the magnitude and phase of I and Q.
| correction | the complex correction (1.0 is full-scale) |
Set the RX sample rate.
| rate | the rate in Sps |
Set the RX frontend specification: The subdev spec maps a physical part of a daughter-board to a channel number. Set the subdev spec before calling into any methods with a channel number. The subdev spec must be the same size across all motherboards.
| spec | the new frontend specification |
Set the time registers on the usrp at the next pps tick. The values will not be latched in until the pulse occurs. It is recommended that the user sleep(1) after calling to ensure that the time registers will be in a known state prior to use.
Note: Because this call sets the time on the "next" pps, the seconds in the time spec should be current seconds + 1.
| time_spec | the time to latch into the usrp device |
Sets the time registers on the usrp immediately.
If only one MIMO master is present in your configuration, set_time_now is safe to use because the slave's time automatically follows the master's time. Otherwise, this call cannot set the time synchronously across multiple devices. Please use the set_time_next_pps or set_time_unknown_pps calls with a PPS signal.
Set the time source for the usrp device. This sets the method of time synchronization, typically a pulse per second or an encoded time. Typical options for source: external, MIMO.
| source | a string representing the time source |
Synchronize the times across all motherboards in this configuration. Use this method to sync the times when the edge of the PPS is unknown.
Ex: Host machine is not attached to serial port of GPSDO and can therefore not query the GPSDO for the PPS edge.
This is a 2-step process, and will take at most 2 seconds to complete. Upon completion, the times will be synchronized to the time provided.
| time_spec | the time to latch at the next pps after catching the edge |
Select the TX antenna on the frontend.
Set the TX bandwidth on the frontend.
Set a constant TX DC offset value. The value is complex to control both I and Q.
Set the TX center frequency.
Set the TX gain value for the specified gain element. For an empty name, distribute across all gain elements.
inline |
Set the TX frontend IQ imbalance correction. Use this to adjust the magnitude and phase of I and Q.
Set the TX sample rate.
Set the TX frontend specification: The subdev spec maps a physical part of a daughter-board to a channel number. Set the subdev spec before calling into any methods with a channel number. The subdev spec must be the same size across all motherboards.
Perform write on the user configuration register bus. These only exist if the user has implemented custom setting registers in the device FPGA.
| addr | 8-bit register address |
| data | 32-bit register value |
| mboard | which motherboard to set the user register |
1.8.13
