UHD  003.007.000-0-g7fef199d
Public Types | Static Public Member Functions | List of all members
uhd::task Class Reference
#include <tasks.hpp>
◆ task_fcn_type
◆ make()
static sptr uhd::task::make ( const task_fcn_type task_fcn)
a new task object
