UHD  003.007.002-0-g25f67e01
Public Types | Public Member Functions | List of all members
uhd::i2c_iface Class Referenceabstract
#include <serial.hpp>
Inheritance diagram for uhd::i2c_iface:
uhd::usrp::dboard_iface
virtual ~i2c_iface (void)
virtual void write_i2c (boost::uint16_t addr, const byte_vector_t &buf)=0
virtual byte_vector_t read_i2c (boost::uint16_t addr, size_t num_bytes)=0
virtual void write_eeprom (boost::uint16_t addr, boost::uint16_t offset, const byte_vector_t &buf)
virtual byte_vector_t read_eeprom (boost::uint16_t addr, boost::uint16_t offset, size_t num_bytes)
typedef boost::shared_ptr<i2c_iface> uhd::i2c_iface::sptr
◆ ~i2c_iface()
virtual uhd::i2c_iface::~i2c_iface ( void  )
virtual
◆ eeprom16()
i2c_iface::sptr uhd::i2c_iface::eeprom16 ( void  )
◆ read_eeprom()
virtual byte_vector_t uhd::i2c_iface::read_eeprom ( boost::uint16_t  addr,
size_t  num_bytes
virtual
Read bytes from an eeprom.
addrthe address
offsetbyte offset
num_bytesnumber of bytes to read
a vector of bytes
◆ read_i2c()
virtual byte_vector_t uhd::i2c_iface::read_i2c ( boost::uint16_t  addr,
size_t  num_bytes
Read bytes over the i2c.
addrthe address
a vector of bytes
◆ write_eeprom()
virtual void uhd::i2c_iface::write_eeprom ( boost::uint16_t  addr,
const byte_vector_t buf
virtual
Write bytes to an eeprom.
addrthe address
offsetbyte offset
bufthe vector of bytes
◆ write_i2c()
virtual void uhd::i2c_iface::write_i2c ( boost::uint16_t  addr,
Write bytes over the i2c.
addrthe address
