UHD  003.007.002-0-g25f67e01
Public Types | Public Member Functions | Static Public Member Functions | Public Attributes | List of all members
uhd::clock_config_t Struct Reference
#include <clock_config.hpp>
enum  ref_source_t { REF_AUTO = int('a'), REF_INT = int('i'), REF_SMA = int('s'), REF_MIMO = int('m') }
enum  pps_source_t { PPS_INT = int('i'), PPS_SMA = int('s'), PPS_MIMO = int('m') }
enum  pps_polarity_t { PPS_NEG = int('n'), PPS_POS = int('p') }
 clock_config_t (void)
static clock_config_t external (void)
 A convenience function to create an external clock configuration. More...
static clock_config_t internal (void)
 A convenience function to create an internal clock configuration. More...
Public Attributes
enum uhd::clock_config_t::ref_source_t ref_source
enum uhd::clock_config_t::pps_source_t pps_source
enum uhd::clock_config_t::pps_polarity_t pps_polarity
◆ pps_polarity_t
Enumerator
PPS_NEG
PPS_POS
◆ pps_source_t
Enumerator
PPS_INT
PPS_SMA
PPS_MIMO
◆ ref_source_t
Enumerator
REF_AUTO
REF_INT
REF_SMA
REF_MIMO
◆ clock_config_t()
uhd::clock_config_t::clock_config_t ( void  )
◆ external()
static clock_config_t uhd::clock_config_t::external ( void  )
◆ internal()
static clock_config_t uhd::clock_config_t::internal ( void  )
◆ pps_polarity
enum uhd::clock_config_t::pps_polarity_t uhd::clock_config_t::pps_polarity
◆ pps_source
enum uhd::clock_config_t::pps_source_t uhd::clock_config_t::pps_source
◆ ref_source
enum uhd::clock_config_t::ref_source_t uhd::clock_config_t::ref_source
