UHD  003.007.002-0-g25f67e01
uhd::meta_range_t Struct Reference
#include <ranges.hpp>
Inheritance diagram for uhd::meta_range_t:
 meta_range_t (void)
 A default constructor for an empty meta-range. More...
template<typename InputIterator >
 meta_range_t (InputIterator first, InputIterator last)
 meta_range_t (double start, double stop, double step=0)
double start (void) const
 Get the overall start value for this meta-range. More...
double stop (void) const
 Get the overall stop value for this meta-range. More...
double step (void) const
 Get the overall step value for this meta-range. More...
double clip (double value, bool clip_step=false) const
const std::string to_pp_string (void) const
 Convert this meta-range to a printable string. More...
A meta-range object holds a list of individual ranges.
◆ meta_range_t() [1/3]
uhd::meta_range_t::meta_range_t ( void  )
◆ meta_range_t() [2/3]
uhd::meta_range_t::meta_range_t ( InputIterator  first,
InputIterator  last
Input iterator constructor: Makes boost::assign::list_of work.
firstthe begin iterator
lastthe end iterator
◆ meta_range_t() [3/3]
uhd::meta_range_t::meta_range_t ( double  start,
double  stop,
double  step = 0
A convenience constructor for a single range. A step size of zero implies infinite precision.
startthe minimum value for this range
stopthe maximum value for this range
stepthe step size for this range
◆ clip()
double uhd::meta_range_t::clip ( double  value,
bool  clip_step = false
) const
Clip the target value to a possible range value.
valuethe value to clip to this range
clip_stepif true, clip to steps as well
a value that is in one of the ranges
◆ start()
double uhd::meta_range_t::start ( void  ) const
◆ step()
double uhd::meta_range_t::step ( void  ) const
◆ stop()
double uhd::meta_range_t::stop ( void  ) const
◆ to_pp_string()
const std::string uhd::meta_range_t::to_pp_string ( void  ) const
