nirio_driver_iface Namespace Reference
Classes
struct  rio_mmap_t
Typedefs
typedef io_connect_t rio_dev_handle_t
Functions
nirio_status rio_open (const std::string &device_path, rio_dev_handle_t &device_handle)
void rio_close (rio_dev_handle_t &device_handle)
bool rio_isopen (rio_dev_handle_t device_handle)
nirio_status rio_ioctl (rio_dev_handle_t device_handle, uint32_t ioctl_code, const void *write_buf, size_t write_buf_len, void *read_buf, size_t read_buf_len)
nirio_status rio_mmap (rio_dev_handle_t device_handle, uint16_t memory_type, size_t size, bool writable, rio_mmap_t &map)
nirio_status rio_munmap (rio_mmap_t &map)
Variables
const uint32_t NIRIO_IOCTL_BASE = 0x800
const uint32_t NIRIO_IOCTL_SYNCOP
const uint32_t NIRIO_IOCTL_GET_IFACE_NUM
 Get the interface number for a device. More...
const uint32_t NIRIO_IOCTL_GET_SESSION
 Gets a previously opened session to a device. More...
const uint32_t NIRIO_IOCTL_POST_OPEN
 Called after opening a session. More...
const uint32_t NIRIO_IOCTL_PRE_CLOSE
 Called before closing a session. More...
Typedef Documentation
◆ rio_dev_handle_t
Function Documentation
◆ rio_close()
void nirio_driver_iface::rio_close ( rio_dev_handle_t device_handle)
◆ rio_ioctl()
nirio_status nirio_driver_iface::rio_ioctl ( rio_dev_handle_t  device_handle,
const void *  write_buf,
void *  read_buf,
size_t  read_buf_len
◆ rio_isopen()
bool nirio_driver_iface::rio_isopen ( rio_dev_handle_t  device_handle)
◆ rio_mmap()
nirio_status nirio_driver_iface::rio_mmap ( rio_dev_handle_t  device_handle,
size_t  size,
bool  writable,
rio_mmap_t map
◆ rio_munmap()
nirio_status nirio_driver_iface::rio_munmap ( rio_mmap_t map)
◆ rio_open()
nirio_status nirio_driver_iface::rio_open ( const std::string &  device_path,
Variable Documentation
◆ NIRIO_IOCTL_BASE
const uint32_t nirio_driver_iface::NIRIO_IOCTL_BASE = 0x800
◆ NIRIO_IOCTL_GET_IFACE_NUM
const uint32_t nirio_driver_iface::NIRIO_IOCTL_GET_IFACE_NUM
Initial value:
Definition: nirio_driver_iface.h:42
◆ NIRIO_IOCTL_GET_SESSION
const uint32_t nirio_driver_iface::NIRIO_IOCTL_GET_SESSION
Initial value:
◆ NIRIO_IOCTL_POST_OPEN
const uint32_t nirio_driver_iface::NIRIO_IOCTL_POST_OPEN
Initial value:
◆ NIRIO_IOCTL_PRE_CLOSE
const uint32_t nirio_driver_iface::NIRIO_IOCTL_PRE_CLOSE
Initial value:
◆ NIRIO_IOCTL_SYNCOP
const uint32_t nirio_driver_iface::NIRIO_IOCTL_SYNCOP
Initial value:
The synchronous operation code. Note: We must use METHOD_OUT_DIRECT on the syncOp() IOCTL to ensure the contents of the output block are available in the kernel.
