Classes | |
| struct | rio_mmap_t |
Typedefs | |
| typedef io_connect_t | rio_dev_handle_t |
Functions | |
| nirio_status | rio_open (const std::string &device_path, rio_dev_handle_t &device_handle) |
| void | rio_close (rio_dev_handle_t &device_handle) |
| bool | rio_isopen (rio_dev_handle_t device_handle) |
| nirio_status | rio_ioctl (rio_dev_handle_t device_handle, uint32_t ioctl_code, const void *write_buf, size_t write_buf_len, void *read_buf, size_t read_buf_len) |
| nirio_status | rio_mmap (rio_dev_handle_t device_handle, uint16_t memory_type, size_t size, bool writable, rio_mmap_t &map) |
| nirio_status | rio_munmap (rio_mmap_t &map) |
Variables | |
| const uint32_t | NIRIO_IOCTL_BASE = 0x800 |
| const uint32_t | NIRIO_IOCTL_SYNCOP |
| const uint32_t | NIRIO_IOCTL_GET_IFACE_NUM |
| Get the interface number for a device.  More... | |
| const uint32_t | NIRIO_IOCTL_GET_SESSION |
| Gets a previously opened session to a device.  More... | |
| const uint32_t | NIRIO_IOCTL_POST_OPEN |
| Called after opening a session.  More... | |
| const uint32_t | NIRIO_IOCTL_PRE_CLOSE |
| Called before closing a session.  More... | |
| typedef io_connect_t nirio_driver_iface::rio_dev_handle_t |
| void nirio_driver_iface::rio_close | ( | rio_dev_handle_t & | device_handle | ) |
| nirio_status nirio_driver_iface::rio_ioctl | ( | rio_dev_handle_t | device_handle, |
| uint32_t | ioctl_code, | ||
| const void * | write_buf, | ||
| size_t | write_buf_len, | ||
| void * | read_buf, | ||
| size_t | read_buf_len | ||
| bool nirio_driver_iface::rio_isopen | ( | rio_dev_handle_t | device_handle | ) |
| nirio_status nirio_driver_iface::rio_mmap | ( | rio_dev_handle_t | device_handle, |
| uint16_t | memory_type, | ||
| size_t | size, | ||
| bool | writable, | ||
| rio_mmap_t & | map | ||
| nirio_status nirio_driver_iface::rio_munmap | ( | rio_mmap_t & | map | ) |
| nirio_status nirio_driver_iface::rio_open | ( | const std::string & | device_path, |
| rio_dev_handle_t & | device_handle | ||
| const uint32_t nirio_driver_iface::NIRIO_IOCTL_BASE = 0x800 |
| const uint32_t nirio_driver_iface::NIRIO_IOCTL_GET_IFACE_NUM |
| const uint32_t nirio_driver_iface::NIRIO_IOCTL_GET_SESSION |
| const uint32_t nirio_driver_iface::NIRIO_IOCTL_POST_OPEN |
| const uint32_t nirio_driver_iface::NIRIO_IOCTL_PRE_CLOSE |
| const uint32_t nirio_driver_iface::NIRIO_IOCTL_SYNCOP |
The synchronous operation code. Note: We must use METHOD_OUT_DIRECT on the syncOp() IOCTL to ensure the contents of the output block are available in the kernel.
