niriok_proxy_impl_v2.h File Reference
#include <boost/smart_ptr.hpp>
#include <boost/noncopyable.hpp>
#include <uhd/transport/nirio/nirio_driver_iface.h>
#include <uhd/transport/nirio/nirio_quirks.h>
#include <uhd/transport/nirio/niriok_proxy.h>
Classes
struct  uhd::niusrprio::nirio_fifo_data_type_t
class  uhd::niusrprio::niriok_proxy_impl_v2
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_get32
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_get32
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_set32
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_set32
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_get_string
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_set_string
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_reset
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_reset
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_add_input_fifo_resource
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_addInputFifo_resource
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_addOutputFifo_resource
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_addOutputFifo_resource
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_setDevice_config
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_setDevice_config
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_fifo_config
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_fifo_config
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_fifo_start
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_fifo_start
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_fifo_stop
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_fifo_stop
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_fifo_read
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_fifo_read
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_fifo_write
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_fifo_write
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_fifo_wait
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_fifo_wait
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_fifo_grant
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_fifo_grant
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_fifoStop_all
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_fifoStop_all
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_peek64
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_peek64
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_peek32
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_peek32
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_poke64
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_poke64
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_poke32
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_poke32
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_post_open
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_post_open
struct  uhd::niusrprio::niriok_proxy_impl_v2::in_transport_pre_close
struct  uhd::niusrprio::niriok_proxy_impl_v2::out_transport_pre_close
Namespaces
 uhd
 uhd::niusrprio
Macros
#define IOCTL(type, function, access)   CTL_CODE((0x8000+type), (0x800+function), METHOD_BUFFERED, access)
#define IOCTL_ACCESS_ANY   (FILE_ANY_ACCESS)
#define IOCTL_ACCESS_READ   (FILE_READ_ACCESS)
#define IOCTL_ACCESS_WRITE   (FILE_WRITE_ACCESS)
#define IOCTL_ACCESS_RW   (FILE_READ_ACCESS | FILE_WRITE_ACCESS)
#define IOCTL_TRANSPORT_GET32   IOCTL(0, 0, IOCTL_ACCESS_READ)
#define IOCTL_TRANSPORT_SET32   IOCTL(0, 1, IOCTL_ACCESS_WRITE)
#define IOCTL_TRANSPORT_GET_STRING   IOCTL(0, 2, IOCTL_ACCESS_READ)
#define IOCTL_TRANSPORT_SET_STRING   IOCTL(0, 3, IOCTL_ACCESS_WRITE)
#define IOCTL_TRANSPORT_RESET   IOCTL(1, 1, IOCTL_ACCESS_WRITE)
#define IOCTL_TRANSPORT_ADD_INPUT_FIFO_RESOURCE   IOCTL(2, 0, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_ADD_OUTPUT_FIFO_RESOURCE   IOCTL(2, 1, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_SET_DEVICE_CONFIG   IOCTL(2, 3, IOCTL_ACCESS_WRITE)
#define IOCTL_TRANSPORT_FIFO_CONFIG   IOCTL(4, 0, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_FIFO_START   IOCTL(4, 1, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_FIFO_STOP   IOCTL(4, 2, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_FIFO_READ   IOCTL(4, 3, IOCTL_ACCESS_READ)
#define IOCTL_TRANSPORT_FIFO_WRITE   IOCTL(4, 4, IOCTL_ACCESS_WRITE)
#define IOCTL_TRANSPORT_FIFO_WAIT   IOCTL(4, 5, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_FIFO_GRANT   IOCTL(4, 6, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_FIFO_STOP_ALL   IOCTL(4, 7, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_PEEK64   IOCTL(5, 2, IOCTL_ACCESS_READ)
#define IOCTL_TRANSPORT_PEEK32   IOCTL(5, 3, IOCTL_ACCESS_READ)
#define IOCTL_TRANSPORT_POKE64   IOCTL(5, 6, IOCTL_ACCESS_WRITE)
#define IOCTL_TRANSPORT_POKE32   IOCTL(5, 7, IOCTL_ACCESS_WRITE)
#define IOCTL_TRANSPORT_POST_OPEN   IOCTL(8, 0, IOCTL_ACCESS_ANY)
#define IOCTL_TRANSPORT_PRE_CLOSE   IOCTL(8, 1, IOCTL_ACCESS_ANY)
Typedefs
typedef uint64_t tAlignedU64
◆ IOCTL
#define IOCTL (   type,
  function,
  access
◆ IOCTL_ACCESS_ANY
◆ IOCTL_ACCESS_READ
◆ IOCTL_ACCESS_RW
◆ IOCTL_ACCESS_WRITE
◆ IOCTL_TRANSPORT_ADD_INPUT_FIFO_RESOURCE
◆ IOCTL_TRANSPORT_ADD_OUTPUT_FIFO_RESOURCE
◆ IOCTL_TRANSPORT_FIFO_CONFIG
◆ IOCTL_TRANSPORT_FIFO_GRANT
◆ IOCTL_TRANSPORT_FIFO_READ
◆ IOCTL_TRANSPORT_FIFO_START
◆ IOCTL_TRANSPORT_FIFO_STOP
◆ IOCTL_TRANSPORT_FIFO_STOP_ALL
◆ IOCTL_TRANSPORT_FIFO_WAIT
◆ IOCTL_TRANSPORT_FIFO_WRITE
◆ IOCTL_TRANSPORT_GET32
◆ IOCTL_TRANSPORT_GET_STRING
◆ IOCTL_TRANSPORT_PEEK32
◆ IOCTL_TRANSPORT_PEEK64
◆ IOCTL_TRANSPORT_POKE32
◆ IOCTL_TRANSPORT_POKE64
◆ IOCTL_TRANSPORT_POST_OPEN
◆ IOCTL_TRANSPORT_PRE_CLOSE
◆ IOCTL_TRANSPORT_RESET
◆ IOCTL_TRANSPORT_SET32
◆ IOCTL_TRANSPORT_SET_DEVICE_CONFIG
◆ IOCTL_TRANSPORT_SET_STRING
Typedef Documentation
◆ tAlignedU64
