stream.hpp
2 // Copyright 2011-2013 Ettus Research LLC
18 #ifndef INCLUDED_UHD_STREAM_HPP
19 #define INCLUDED_UHD_STREAM_HPP
22 #include <uhd/types/metadata.hpp>
24 #include <uhd/types/stream_cmd.hpp>
25 #include <uhd/types/ref_vector.hpp>
26 #include <boost/utility.hpp>
27 #include <boost/shared_ptr.hpp>
28 #include <vector>
29 #include <string>
30
31 namespace uhd{
32
41
44  const std::string &cpu = "",
45  const std::string &otw = ""
46  ){
47  cpu_format = cpu;
48  otw_format = otw;
49  }
50
65  std::string cpu_format;
66
77  std::string otw_format;
78
109
116  std::vector<size_t> channels;
117 };
118
124 class UHD_API rx_streamer : boost::noncopyable{
125 public:
126  typedef boost::shared_ptr<rx_streamer> sptr;
127
128  virtual ~rx_streamer(void);
129
131  virtual size_t get_num_channels(void) const = 0;
132
134  virtual size_t get_max_num_samps(void) const = 0;
135
138
169  virtual size_t recv(
170  const buffs_type &buffs,
171  const size_t nsamps_per_buff,
172  rx_metadata_t &metadata,
173  const double timeout = 0.1,
174  const bool one_packet = false
175  ) = 0;
176
188  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd) = 0;
189 };
190
196 class UHD_API tx_streamer : boost::noncopyable{
197 public:
198  typedef boost::shared_ptr<tx_streamer> sptr;
199
200  virtual ~tx_streamer(void);
201
203  virtual size_t get_num_channels(void) const = 0;
204
206  virtual size_t get_max_num_samps(void) const = 0;
207
210
232  virtual size_t send(
233  const buffs_type &buffs,
234  const size_t nsamps_per_buff,
235  const tx_metadata_t &metadata,
236  const double timeout = 0.1
237  ) = 0;
238
245  virtual bool recv_async_msg(
246  async_metadata_t &async_metadata, double timeout = 0.1
247  ) = 0;
248 };
249
250 } //namespace uhd
251
252 #endif /* INCLUDED_UHD_STREAM_HPP */
Definition: stream_cmd.hpp:46
Definition: stream.hpp:124
Definition: stream.hpp:196
std::vector< size_t > channels
Definition: stream.hpp:116
Definition: stream.hpp:126
Definition: stream.hpp:77
Definition: metadata.hpp:32
Definition: metadata.hpp:141
Definition: config.hpp:79
Definition: stream.hpp:65
Definition: ref_vector.hpp:30
ref_vector< void * > buffs_type
Typedef for a pointer to a single, or a collection of recv buffers.
Definition: stream.hpp:137
stream_args_t(const std::string &cpu="", const std::string &otw="")
Convenience constructor for streamer args.
Definition: stream.hpp:43
size_t send(const send_buffs_type &buffs, size_t nsamps_per_buff, const tx_metadata_t &metadata, const io_type_t &io_type, send_mode_t send_mode, double timeout=0.1)
Definition: device_deprecated.ipp:74
device_addr_t args
Definition: stream.hpp:108
ref_vector< const void * > buffs_type
Typedef for a pointer to a single, or a collection of send buffers.
Definition: stream.hpp:209
Definition: stream.hpp:40
Definition: metadata.hpp:168
Definition: stream.hpp:198
size_t recv(const recv_buffs_type &buffs, size_t nsamps_per_buff, rx_metadata_t &metadata, const io_type_t &io_type, recv_mode_t recv_mode, double timeout=0.1)
Definition: device_deprecated.ipp:130
virtual bool recv_async_msg(async_metadata_t &async_metadata, double timeout=0.1)=0
