uhd::stream_args_t Struct Reference
#include <uhd/stream.hpp>
 stream_args_t (const std::string &cpu="", const std::string &otw="")
 Convenience constructor for streamer args. More...
Public Attributes
std::string cpu_format
std::string otw_format
device_addr_t args
std::vector< size_t > channels
◆ stream_args_t()
uhd::stream_args_t::stream_args_t ( const std::string &  cpu = "",
const std::string &  otw = ""
◆ args
device_addr_t uhd::stream_args_t::args
  • fullscale: specifies the full-scale amplitude when using floats. By default, the fullscale amplitude under floating point is 1.0. Set the "fullscale" to scale the samples in the host to the expected input range and/or output range of your application.
  • peak: specifies a fractional sample level to calculate scaling with the sc8 wire format. When using sc8 samples over the wire, the device must scale samples (both on the host and in the device) to satisfy the dynamic range needs. The peak value specifies a fraction of the maximum sample level (1.0 = 100%). Set peak to max_sample_level/full_scale_level to ensure optimum dynamic range.
  • underflow_policy: how the TX DSP should recover from underflow. Possible options are "next_burst" or "next_packet". In the "next_burst" mode, the DSP drops incoming packets until a new burst is started. In the "next_packet" mode, the DSP starts transmitting again at the next packet.
  • spp: (samples per packet) controls the size of RX packets. When not specified, the packets are always maximum frame size. Users should specify this option to request smaller than default packets, probably with the intention of reducing packet latency.
  • function: magnitude or phase/magnitude
  • units: numeric units like counts or dBm
◆ channels
std::vector<size_t> uhd::stream_args_t::channels
The channels is a list of channel numbers. Leave this blank to default to channel 0. Set channels for a multi-channel application. Channel mapping depends on the front-end selection.
◆ cpu_format
std::string uhd::stream_args_t::cpu_format
  • fc64 - complex<double>
  • fc32 - complex<float>
  • sc16 - complex<int16_t>
  • sc8 - complex<int8_t>
  • f32 - float
  • f64 - double
  • s16 - int16_t
  • s8 - int8_t
◆ otw_format
std::string uhd::stream_args_t::otw_format
  • sc16 - Q16 I16
  • sc8 - Q8_1 I8_1 Q8_0 I8_0
  • s16 - R16_1 R16_0
  • s8 - R8_3 R8_2 R8_1 R8_0
