Note: More build information can be found on the UHD wiki page, at http://code.ettus.com/redmine/ettus/projects/uhd/wiki .
Mac OS X Notes: Install the Xcode app to get the build tools (GCC and Make). Use MacPorts to get the Boost and Cheetah dependencies. Other dependencies can be downloaded as DMG installers from the web or installed via MacPorts. See the UHD OS X page for more information: http://code.ettus.com/redmine/ettus/projects/uhd/wiki/UHD_OS_X
Required to check out the repository. On Windows, install Cygwin with Git support to checkout the repository or install msysGit from http://code.google.com/p/msysgit/downloads/list.
Download URL (Windows installer): http://feisley.com/python/cheetah/
Alternative method:** Install setuptools, and use the easy_install command to install Cheetah. http://pypi.python.org/pypi/setuptools
Download URL: http://www.stack.nl/~dimitri/doxygen/download.html#latestsrc
Alternate method:** Install setuptools, and use the easy_install command to install Docutils. http://pypi.python.org/pypi/setuptools
cd <uhd-repo-path>/host mkdir build cd build cmake ../
-DCMAKE_INSTALL_PREFIX=<install-path>cmake -DLIB_SUFFIX=64Example usage:
make make test sudo make install
sudo ldconfig
<uhd-repo-path>/host.<uhd-repo-path>/host/build.On Windows, CMake does not have the advantage of pkg-config, so we must manually tell CMake how to locate the LibUSB header and lib.
LIBUSB_INCLUDE_DIRS to the directory with libusb.h.LIBUSB_LIBRARIES to the full path for libusb-1.0.lib.libusb-1.0.lib to simplify runtime dependencies.Note: On Windows, LibUSB v1.0.19 is required to use most USB3 controllers.
cd <uhd-repo-path>\host\build DevEnv uhd.sln /build Release /project ALL_BUILD DevEnv uhd.sln /build Release /project INSTALL
For USB-based devices, see the USB Transport Application Notes <./transport.html::usb-transport-libusb>_ for platform-specific post-installation tasks.
Make sure that the value of CMAKE_INSTALL_PREFIX is at or near the front of the shell PATH environment variable. Do NOT set DYLD_LIBRARY_PATH or any related DYLD environment variable permanently; these work differently than under Linux and should be used for testing / temporary purposes only.
