USRP Hardware Driver and USRP Manual  Version: 003.008.003-0-g87dfdc3c
uhd::property< T > Class Template Referenceabstract
Inheritance diagram for uhd::property< T >:
typedef boost::function< void(const T &)> subscriber_type
typedef boost::function< T(void)> publisher_type
typedef boost::function< T(const T &)> coercer_type
virtual ~property (void)=0
virtual property< T > & coerce (const coercer_type &coercer)=0
virtual property< T > & publish (const publisher_type &publisher)=0
virtual property< T > & subscribe (const subscriber_type &subscriber)=0
virtual property< T > & update (void)=0
virtual property< T > & set (const T &value)=0
virtual T get (void) const =0
virtual bool empty (void) const =0
template<typename T>
class uhd::property< T >
A templated property interface for holding a value and registering callbacks when that value changes.
◆ coercer_type
typedef boost::function<T(const T &)> uhd::property< T >::coercer_type
◆ publisher_type
typedef boost::function<T(void)> uhd::property< T >::publisher_type
◆ subscriber_type
typedef boost::function<void(const T &)> uhd::property< T >::subscriber_type
◆ ~property()
template<typename T >
uhd::property< T >::~property ( void  )
◆ coerce()
virtual property<T>& uhd::property< T >::coerce ( const coercer_type coercer)
Register a coercer into the property. A coercer is a special subscriber that coerces the value. Only one coercer may be registered per property. Registering a coercer replaces the previous coercer.
coercerthe coercer callback function
a reference to this property for chaining
◆ empty()
virtual bool uhd::property< T >::empty ( void  ) const
A property is empty if it has never been set. A property with a publisher is never empty.
true if the property is empty
virtual T uhd::property< T >::get ( void  ) const
Get the current value of this property. The publisher (when provided) yields the value, otherwise an internal shadow is used for the value.
the current value in the property
◆ publish()
virtual property<T>& uhd::property< T >::publish ( const publisher_type publisher)
Register a publisher into the property. A publisher is a special callback the provides the value. Publishers are useful for creating read-only properties. Only one publisher may be registered per property. Registering a publisher replaces the previous publisher.
publisherthe publisher callback function
virtual property<T>& uhd::property< T >::set ( const T &  value)
Set the new value and call all subscribers. The coercer (when provided) is called initially, and the coerced value is used to set the subscribers.
valuethe new value to set on this property
◆ subscribe()
virtual property<T>& uhd::property< T >::subscribe ( const subscriber_type subscriber)
Register a subscriber into the property. All subscribers are called when the value changes. Once a subscriber is registered, it cannot be unregistered.
subscriberthe subscriber callback function
◆ update()
virtual property<T>& uhd::property< T >::update ( void  )
Update calls all subscribers w/ the current value.
