USRP Hardware Driver and USRP Manual  Version: 003.008.003-0-g87dfdc3c
uhd::task Class Reference
#include <uhd/utils/tasks.hpp>
◆ task_fcn_type
◆ make()
static sptr uhd::task::make ( const task_fcn_type task_fcn)
a new task object
