#include <uhd/usrp/dboard_id.hpp>
◆ dboard_id_t()
          | uhd::usrp::dboard_id_t::dboard_id_t  |
          boost::uint16_t  |
          id = 0xffff | ) |
- Parameters
    | id | the integer representation  |
◆ from_string()
          | static dboard_id_t uhd::usrp::dboard_id_t::from_string  |
          const std::string &  |
          string | ) |
static   |
- Parameters
    | string | a numeric string, possibly hex  |
- Returns
 - a new dboard id containing the integer
◆ from_uint16()
          | static dboard_id_t uhd::usrp::dboard_id_t::from_uint16  |
          boost::uint16_t  |
          uint16 | ) |
static   |
- Parameters
    | uint16 | an unsigned 16 bit integer  |
- Returns
◆ none()
          | static dboard_id_t uhd::usrp::dboard_id_t::none  |
          void  |
static   |
- Returns
 - the dboard id with the 0xffff id.
◆ to_cname()
          | std::string uhd::usrp::dboard_id_t::to_cname  |
          void  |
           const |
- Returns
 - the canonical string representation
◆ to_pp_string()
          | std::string uhd::usrp::dboard_id_t::to_pp_string  |
          void  |
           const |
- Returns
 - a string with the dboard name and id number
◆ to_string()
          | std::string uhd::usrp::dboard_id_t::to_string  |
          void  |
           const |
- Returns
 - a hex string representation with 0x prefix
◆ to_uint16()
          | boost::uint16_t uhd::usrp::dboard_id_t::to_uint16  |
          void  |
           const |
- Returns
 - an unsigned 16 bit integer representation
