USRP Hardware Driver and USRP Manual  Version: 003.008.003-0-g87dfdc3c
Building and Installing UHD
Note: More build information can be found on the UHD wiki page, at http://code.ettus.com/redmine/ettus/projects/uhd/wiki .
Build Dependencies
Mac OS X Notes: Install the Xcode app to get the build tools (GCC and Make). Use MacPorts to get the Boost and Cheetah dependencies. Other dependencies can be downloaded as DMG installers from the web or installed via MacPorts. See the UHD OS X page for more information: http://code.ettus.com/redmine/ettus/projects/uhd/wiki/UHD_OS_X
Git
Required to check out the repository. On Windows, install Cygwin with Git support to checkout the repository or install msysGit from http://code.google.com/p/msysgit/downloads/list.
C++ Compiler
  • GCC >= 4.4
  • Clang >= 3.1
  • MSVC >= 2010
CMake
Boost
LibUSB
Python
  • Purpose: used by Cheetah and utility scripts
  • Minimum Version: 2.6
  • Usage: build time + runtime utility scripts (required)
  • Download URL: http://www.python.org/download/
Cheetah
Doxygen
Build Instructions (Unix)
Generate Makefiles with CMake
cd <uhd-repo-path>/host
mkdir build
cd build
cmake ../
  • For a custom install prefix: -DCMAKE_INSTALL_PREFIX=<install-path>
  • To install libs into lib64: cmake -DLIB_SUFFIX=64
Example usage:
Build and install
make
make test
sudo make install
Setup the library path (Linux)
sudo ldconfig
Build Instructions (Windows)
Generate the project with CMake
  • Open the CMake GUI.
  • Set the path to the source code: <uhd-repo-path>/host.
  • Set the path to the build directory: <uhd-repo-path>/host/build.
  • Make sure that the paths do not contain spaces.
  • Click "Configure" and select "Microsoft Visual Studio 10".
  • Set the build variables and click "Configure" again.
  • Click "Generate", and a project file will be created in the build directory.
LibUSB notes
On Windows, CMake does not have the advantage of pkg-config, so we must manually tell CMake how to locate the LibUSB header and lib.
  • From the CMake GUI, select "Advanced View".
  • Set LIBUSB_INCLUDE_DIRS to the directory with libusb.h.
  • Set LIBUSB_LIBRARIES to the full path for libusb-1.0.lib.
  • Recommend the static libusb-1.0.lib to simplify runtime dependencies.
  • Check the box to enable USB support, click "Configure" and "Generate".
Note: On Windows, LibUSB v1.0.19 is required to use most USB3 controllers.
Build the project in MSVC
  • Open the generated project file in MSVC.
  • Change the build type from "Debug" to "Release".
  • Select the "Build All" target, right-click, and choose "Build".
  • Select the install target, right-click, and choose "Build".
Build the project in MSVC (command line)
cd <uhd-repo-path>\host\build
DevEnv uhd.sln /build Release /project ALL_BUILD
DevEnv uhd.sln /build Release /project INSTALL
Setup the PATH environment variable
Post-Install Tasks
For USB-based devices, see the USB Transport Application Notes <./transport.html::usb-transport-libusb>_ for platform-specific post-installation tasks.
Post-Install Tasks (Mac OS X)
Make sure that the value of CMAKE_INSTALL_PREFIX is at or near the front of the shell PATH environment variable. Do NOT set DYLD_LIBRARY_PATH or any related DYLD environment variable permanently; these work differently than under Linux and should be used for testing / temporary purposes only.
Building applications that require UHD using CMake
find_package(UHD "3.8.0")
Static Builds
