USRP Hardware Driver and USRP Manual  Version: 003.008.003-0-g87dfdc3c
uhd::rx_metadata_t Struct Reference
enum  error_code_t {
  ERROR_CODE_NONE = 0x0, ERROR_CODE_TIMEOUT = 0x1, ERROR_CODE_LATE_COMMAND = 0x2, ERROR_CODE_BROKEN_CHAIN = 0x4,
  ERROR_CODE_OVERFLOW = 0x8, ERROR_CODE_ALIGNMENT = 0xc, ERROR_CODE_BAD_PACKET = 0xf
 rx_metadata_t ()
 Default constructor. More...
void reset ()
 Reset values. More...
std::string to_pp_string (bool compact=true) const
std::string strerror (void) const
Public Attributes
bool has_time_spec
 Has time specification? More...
time_spec_t time_spec
 Time of the first sample. More...
bool more_fragments
size_t fragment_offset
bool start_of_burst
 Start of burst will be true for the first packet in the chain. More...
bool end_of_burst
 End of burst will be true for the last packet in the chain. More...
enum uhd::rx_metadata_t::error_code_t error_code
bool out_of_sequence
 Out of sequence. The transport has either dropped a packet or received data out of order. More...
◆ error_code_t
  • none
  • late command
  • broken chain
  • overflow
Enumerator
ERROR_CODE_NONE
No error associated with this metadata.
ERROR_CODE_TIMEOUT
No packet received, implementation timed-out.
A stream command was issued in the past.
Expected another stream command.
ERROR_CODE_OVERFLOW
An internal receive buffer has filled or a sequence error has been detected. So, why is this overloaded? Simple: legacy support. It would have been much cleaner to create a separate error code for a sequence error, but that would have broken legacy applications. So, the out_of_sequence flag was added to differentiate between the two error cases. In either case, data is missing between this time_spec and the and the time_spec of the next successful receive.
Multi-channel alignment failed.
The packet could not be parsed.
◆ rx_metadata_t()
uhd::rx_metadata_t::rx_metadata_t ( )
◆ reset()
void uhd::rx_metadata_t::reset ( )
Reset values.
◆ strerror()
std::string uhd::rx_metadata_t::strerror ( void  ) const
Similar to C's strerror() function, creates a std::string describing the error code.
a printable string representing the error.
◆ to_pp_string()
std::string uhd::rx_metadata_t::to_pp_string ( bool  compact = true) const
Convert a rx_metadata_t into a pretty print string.
compactSet to false for a more verbose output.
a printable string representing the metadata.
◆ end_of_burst
bool uhd::rx_metadata_t::end_of_burst
◆ error_code
enum uhd::rx_metadata_t::error_code_t uhd::rx_metadata_t::error_code
◆ fragment_offset
size_t uhd::rx_metadata_t::fragment_offset
◆ has_time_spec
bool uhd::rx_metadata_t::has_time_spec
◆ more_fragments
bool uhd::rx_metadata_t::more_fragments
◆ out_of_sequence
bool uhd::rx_metadata_t::out_of_sequence
◆ start_of_burst
bool uhd::rx_metadata_t::start_of_burst
◆ time_spec
time_spec_t uhd::rx_metadata_t::time_spec
