          | virtual size_t uhd::rx_streamer::recv  |
          const buffs_type &  |
          buffs,  |
          const size_t  |
          nsamps_per_buff,  |
          rx_metadata_t &  |
          metadata,  |
          const double  |
          timeout = 0.1,  |
          const bool  |
          one_packet = false  |
pure virtual   |
Receive handles fragmentation as follows: If the buffer has insufficient space to hold all samples that were received in a single packet over-the-wire, then the buffer will be completely filled and the implementation will hold a pointer into the remaining portion of the packet. Subsequent calls will load from the remainder of the packet, and will flag the metadata to show that this is a fragment. The next call to receive, after the remainder becomes exahausted, will perform an over-the-wire receive as usual. See the rx metadata fragment flags and offset fields for details.
- Parameters
    | buffs | a vector of writable memory to fill with samples  |
    | nsamps_per_buff | the size of each buffer in number of samples  |
    | metadata | data to fill describing the buffer  |
    | timeout | the timeout in seconds to wait for a packet  |
    | one_packet | return after the first packet is received  |
- Returns
 - the number of samples received or 0 on error
