multi_usrp.hpp
18 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP
19 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP
21 //define API capabilities for compile time detection of new features
22 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API
23 #define UHD_USRP_MULTI_USRP_GET_RATES_API
24 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API
25 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API
26 #define UHD_USRP_MULTI_USRP_BW_RANGE_API
27 #define UHD_USRP_MULTI_USRP_USER_REGS_API
28 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API
29 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN
30 #define UHD_USRP_MULTI_USRP_GPIO_API
31
32 #include <uhd/config.hpp>
33 #include <uhd/device.hpp>
34 #include <uhd/deprecated.hpp>
35 #include <uhd/types/ranges.hpp>
36 #include <uhd/types/stream_cmd.hpp>
39 #include <uhd/types/sensors.hpp>
40 #include <uhd/usrp/subdev_spec.hpp>
42 #include <boost/shared_ptr.hpp>
43 #include <boost/utility.hpp>
44 #include <complex>
45 #include <string>
46 #include <vector>
47
48 namespace uhd{ namespace usrp{
49
96 class UHD_API multi_usrp : boost::noncopyable{
97 public:
98  typedef boost::shared_ptr<multi_usrp> sptr;
99
100  virtual ~multi_usrp(void) = 0;
101
103  static const size_t ALL_MBOARDS = size_t(~0);
104
106  static const size_t ALL_CHANS = size_t(~0);
107
109  static const std::string ALL_GAINS;
110
116  static sptr make(const device_addr_t &dev_addr);
117
123  virtual device::sptr get_device(void) = 0;
124
126  virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args) = 0;
127
129  virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args) = 0;
130
138  virtual dict<std::string, std::string> get_usrp_rx_info(size_t chan = 0) = 0;
139
147  virtual dict<std::string, std::string> get_usrp_tx_info(size_t chan = 0) = 0;
148
149  /*******************************************************************
150  * Mboard methods
151  ******************************************************************/
152
163  virtual void set_master_clock_rate(double rate, size_t mboard = ALL_MBOARDS) = 0;
164
170  virtual double get_master_clock_rate(size_t mboard = 0) = 0;
171
176  virtual std::string get_pp_string(void) = 0;
177
183  virtual std::string get_mboard_name(size_t mboard = 0) = 0;
184
190  virtual time_spec_t get_time_now(size_t mboard = 0) = 0;
191
197  virtual time_spec_t get_time_last_pps(size_t mboard = 0) = 0;
198
210  virtual void set_time_now(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
211
224  virtual void set_time_next_pps(const time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
225
241  virtual void set_time_unknown_pps(const time_spec_t &time_spec) = 0;
242
249  virtual bool get_time_synchronized(void) = 0;
250
261  virtual void set_command_time(const uhd::time_spec_t &time_spec, size_t mboard = ALL_MBOARDS) = 0;
262
268  virtual void clear_command_time(size_t mboard = ALL_MBOARDS) = 0;
269
282  virtual void issue_stream_cmd(const stream_cmd_t &stream_cmd, size_t chan = ALL_CHANS) = 0;
283
292  virtual void set_clock_config(const clock_config_t &clock_config, size_t mboard = ALL_MBOARDS) = 0;
293
302  virtual void set_time_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
303
309  virtual std::string get_time_source(const size_t mboard) = 0;
310
316  virtual std::vector<std::string> get_time_sources(const size_t mboard) = 0;
317
325  virtual void set_clock_source(const std::string &source, const size_t mboard = ALL_MBOARDS) = 0;
326
332  virtual std::string get_clock_source(const size_t mboard) = 0;
333
339  virtual std::vector<std::string> get_clock_sources(const size_t mboard) = 0;
340
349  virtual void set_clock_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
350
359  virtual void set_time_source_out(const bool enb, const size_t mboard = ALL_MBOARDS) = 0;
360
364  virtual size_t get_num_mboards(void) = 0;
365
372  virtual sensor_value_t get_mboard_sensor(const std::string &name, size_t mboard = 0) = 0;
373
379  virtual std::vector<std::string> get_mboard_sensor_names(size_t mboard = 0) = 0;
380
388  virtual void set_user_register(const boost::uint8_t addr, const boost::uint32_t data, size_t mboard = ALL_MBOARDS) = 0;
389
390  /*******************************************************************
391  * RX methods
392  ******************************************************************/
401  virtual void set_rx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
402
408  virtual uhd::usrp::subdev_spec_t get_rx_subdev_spec(size_t mboard = 0) = 0;
409
415  virtual size_t get_rx_num_channels(void) = 0;
416
422  virtual std::string get_rx_subdev_name(size_t chan = 0) = 0;
423
429  virtual void set_rx_rate(double rate, size_t chan = ALL_CHANS) = 0;
430
436  virtual double get_rx_rate(size_t chan = 0) = 0;
437
443  virtual meta_range_t get_rx_rates(size_t chan = 0) = 0;
444
451  virtual tune_result_t set_rx_freq(
452  const tune_request_t &tune_request, size_t chan = 0
453  ) = 0;
454
460  virtual double get_rx_freq(size_t chan = 0) = 0;
461
471  virtual freq_range_t get_rx_freq_range(size_t chan = 0) = 0;
472
478  virtual freq_range_t get_fe_rx_freq_range(size_t chan = 0) = 0;
479
487  virtual void set_rx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
488
490  void set_rx_gain(double gain, size_t chan = 0){
491  return this->set_rx_gain(gain, ALL_GAINS, chan);
492  }
493
501  virtual double get_rx_gain(const std::string &name, size_t chan = 0) = 0;
502
504  double get_rx_gain(size_t chan = 0){
505  return this->get_rx_gain(ALL_GAINS, chan);
506  }
507
515  virtual gain_range_t get_rx_gain_range(const std::string &name, size_t chan = 0) = 0;
516
518  gain_range_t get_rx_gain_range(size_t chan = 0){
519  return this->get_rx_gain_range(ALL_GAINS, chan);
520  }
521
528  virtual std::vector<std::string> get_rx_gain_names(size_t chan = 0) = 0;
529
535  virtual void set_rx_antenna(const std::string &ant, size_t chan = 0) = 0;
536
542  virtual std::string get_rx_antenna(size_t chan = 0) = 0;
543
549  virtual std::vector<std::string> get_rx_antennas(size_t chan = 0) = 0;
550
556  virtual void set_rx_bandwidth(double bandwidth, size_t chan = 0) = 0;
557
563  virtual double get_rx_bandwidth(size_t chan = 0) = 0;
564
570  virtual meta_range_t get_rx_bandwidth_range(size_t chan = 0) = 0;
571
579  virtual dboard_iface::sptr get_rx_dboard_iface(size_t chan = 0) = 0;
580
587  virtual sensor_value_t get_rx_sensor(const std::string &name, size_t chan = 0) = 0;
588
594  virtual std::vector<std::string> get_rx_sensor_names(size_t chan = 0) = 0;
595
608  virtual void set_rx_dc_offset(const bool enb, size_t chan = ALL_CHANS) = 0;
609
617  virtual void set_rx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
618
626  virtual void set_rx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
627
628  /*******************************************************************
629  * TX methods
630  ******************************************************************/
639  virtual void set_tx_subdev_spec(const uhd::usrp::subdev_spec_t &spec, size_t mboard = ALL_MBOARDS) = 0;
640
646  virtual uhd::usrp::subdev_spec_t get_tx_subdev_spec(size_t mboard = 0) = 0;
647
653  virtual size_t get_tx_num_channels(void) = 0;
654
660  virtual std::string get_tx_subdev_name(size_t chan = 0) = 0;
661
667  virtual void set_tx_rate(double rate, size_t chan = ALL_CHANS) = 0;
668
674  virtual double get_tx_rate(size_t chan = 0) = 0;
675
681  virtual meta_range_t get_tx_rates(size_t chan = 0) = 0;
682
689  virtual tune_result_t set_tx_freq(
690  const tune_request_t &tune_request, size_t chan = 0
691  ) = 0;
692
698  virtual double get_tx_freq(size_t chan = 0) = 0;
699
709  virtual freq_range_t get_tx_freq_range(size_t chan = 0) = 0;
710
716  virtual freq_range_t get_fe_tx_freq_range(size_t chan = 0) = 0;
717
725  virtual void set_tx_gain(double gain, const std::string &name, size_t chan = 0) = 0;
726
728  void set_tx_gain(double gain, size_t chan = 0){
729  return this->set_tx_gain(gain, ALL_GAINS, chan);
730  }
731
739  virtual double get_tx_gain(const std::string &name, size_t chan = 0) = 0;
740
742  double get_tx_gain(size_t chan = 0){
743  return this->get_tx_gain(ALL_GAINS, chan);
744  }
745
753  virtual gain_range_t get_tx_gain_range(const std::string &name, size_t chan = 0) = 0;
754
756  gain_range_t get_tx_gain_range(size_t chan = 0){
757  return this->get_tx_gain_range(ALL_GAINS, chan);
758  }
759
766  virtual std::vector<std::string> get_tx_gain_names(size_t chan = 0) = 0;
767
773  virtual void set_tx_antenna(const std::string &ant, size_t chan = 0) = 0;
774
780  virtual std::string get_tx_antenna(size_t chan = 0) = 0;
781
787  virtual std::vector<std::string> get_tx_antennas(size_t chan = 0) = 0;
788
794  virtual void set_tx_bandwidth(double bandwidth, size_t chan = 0) = 0;
795
801  virtual double get_tx_bandwidth(size_t chan = 0) = 0;
802
808  virtual meta_range_t get_tx_bandwidth_range(size_t chan = 0) = 0;
809
817  virtual dboard_iface::sptr get_tx_dboard_iface(size_t chan = 0) = 0;
818
825  virtual sensor_value_t get_tx_sensor(const std::string &name, size_t chan = 0) = 0;
826
832  virtual std::vector<std::string> get_tx_sensor_names(size_t chan = 0) = 0;
833
840  virtual void set_tx_dc_offset(const std::complex<double> &offset, size_t chan = ALL_CHANS) = 0;
841
849  virtual void set_tx_iq_balance(const std::complex<double> &correction, size_t chan = ALL_CHANS) = 0;
850
851  /*******************************************************************
852  * GPIO methods
853  ******************************************************************/
854
860  virtual std::vector<std::string> get_gpio_banks(const size_t mboard) = 0;
861
878  virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const boost::uint32_t value, const boost::uint32_t mask = 0xffffffff, const size_t mboard = 0) = 0;
879
896  virtual boost::uint32_t get_gpio_attr(const std::string &bank, const std::string &attr, const size_t mboard = 0) = 0;
897
898 };
899
900 }}
901
902 #endif /* INCLUDED_UHD_USRP_MULTI_USRP_HPP */
Definition: multi_usrp.hpp:518
Definition: stream_cmd.hpp:46
Definition: tune_result.hpp:29
Definition: multi_usrp.hpp:742
Definition: multi_usrp.hpp:728
Definition: time_spec.hpp:39
Definition: device.hpp:41
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:98
Definition: multi_usrp.hpp:504
Definition: tune_request.hpp:33
Definition: stream.hpp:184
A wildcard gain element name.
Definition: multi_usrp.hpp:109
Definition: config.hpp:79
Definition: sensors.hpp:38
Definition: multi_usrp.hpp:96
Definition: stream.hpp:57
Definition: multi_usrp.hpp:490
Definition: ranges.hpp:68
Definition: stream.hpp:256
Definition: multi_usrp.hpp:756
