uhd::analog_filter_lp Class Reference
Inheritance diagram for uhd::analog_filter_lp:
uhd::analog_filter_base uhd::filter_info_base
typedef boost::shared_ptr< analog_filter_lpsptr
- Public Types inherited from uhd::analog_filter_base
typedef boost::shared_ptr< analog_filter_basesptr
- Public Types inherited from uhd::filter_info_base
enum  filter_type { ANALOG_LOW_PASS, ANALOG_BAND_PASS, DIGITAL_I16, DIGITAL_FIR_I16 }
typedef boost::shared_ptr< filter_info_basesptr
 analog_filter_lp (filter_type type, bool bypass, size_t position_index, const std::string &analog_type, double cutoff, double rolloff)
double get_cutoff ()
double get_rolloff ()
void set_cutoff (const double cutoff)
virtual std::string to_pp_string ()
- Public Member Functions inherited from uhd::analog_filter_base
 analog_filter_base (filter_type type, bool bypass, size_t position_index, const std::string &analog_type)
const std::string & get_analog_type ()
- Public Member Functions inherited from uhd::filter_info_base
 filter_info_base (filter_type type, bool bypass, size_t position_index)
virtual bool is_bypassed ()
filter_type get_type ()
virtual ~filter_info_base ()
- Protected Attributes inherited from uhd::filter_info_base
filter_type _type
bool _bypass
size_t _position_index
typedef boost::shared_ptr<analog_filter_lp> uhd::analog_filter_lp::sptr
◆ analog_filter_lp()
uhd::analog_filter_lp::analog_filter_lp ( filter_type  type,
bool  bypass,
const std::string &  analog_type,
double  cutoff,
double  rolloff
◆ get_cutoff()
double uhd::analog_filter_lp::get_cutoff ( )
◆ get_rolloff()
double uhd::analog_filter_lp::get_rolloff ( )
◆ set_cutoff()
void uhd::analog_filter_lp::set_cutoff ( const double  cutoff)
◆ to_pp_string()
virtual std::string uhd::analog_filter_lp::to_pp_string ( )
virtual
Reimplemented from uhd::analog_filter_base.
