uhd::dirty_tracked< data_t > Class Template Reference
#include <uhd/utils/dirty_tracked.hpp>
 dirty_tracked ()
 dirty_tracked (const data_t &value)
 dirty_tracked (const dirty_tracked &source)
const data_t & get () const
bool is_dirty () const
void mark_clean ()
void force_dirty ()
dirty_tracked & operator= (const data_t &value)
dirty_tracked & operator= (const dirty_tracked &source)
 operator const data_t & () const
template<typename data_t>
class uhd::dirty_tracked< data_t >
A class that wraps a data value with a dirty flag When the client uses the assignment operator on this object, the object automatically dirties itself if the assigned type is not equal the underlying data. Data can be cleaned using the mark_clean entry-point.
Requirements for data_t
  • Must have a default constructor
  • Must have a copy constructor
  • Must have an assignment operator (=)
  • Must have an equality operator (==)
◆ dirty_tracked() [1/3]
uhd::dirty_tracked< data_t >::dirty_tracked ( )
Default ctor: Initialize to default value and dirty
◆ dirty_tracked() [2/3]
uhd::dirty_tracked< data_t >::dirty_tracked ( const data_t &  value)
Initialize to specified value and dirty
◆ dirty_tracked() [3/3]
uhd::dirty_tracked< data_t >::dirty_tracked ( const dirty_tracked< data_t > &  source)
Copy ctor: Assign source to this type
◆ force_dirty()
void uhd::dirty_tracked< data_t >::force_dirty ( )
Mark the underlying data as dirty
const data_t& uhd::dirty_tracked< data_t >::get ( void  ) const
Get underlying data
◆ is_dirty()
bool uhd::dirty_tracked< data_t >::is_dirty ( ) const
Has the underlying data changed since the last time it was cleaned?
◆ mark_clean()
void uhd::dirty_tracked< data_t >::mark_clean ( )
Mark the underlying data as clean
◆ operator const data_t &()
uhd::dirty_tracked< data_t >::operator const data_t & ( ) const
Explicit conversion from this type to data_t
◆ operator=() [1/2]
dirty_tracked& uhd::dirty_tracked< data_t >::operator= ( const data_t &  value)
Assignment with data. Store the specified value and mark it as dirty if it is not equal to the underlying data.
◆ operator=() [2/2]
dirty_tracked& uhd::dirty_tracked< data_t >::operator= ( const dirty_tracked< data_t > &  source)
Assignment with dirty tracked type. Store the specified value from dirty type and mark it as dirty if it is not equal to the underlying data. This exists to optimize out an implicit cast from dirty_tracked type to data type.
