#include <uhd/transport/udp_zero_copy.hpp>
Classes | |
struct | buff_params |
Public Types | |
typedef boost::shared_ptr< udp_zero_copy > | sptr |
Public Types inherited from uhd::transport::zero_copy_if | |
typedef boost::shared_ptr< zero_copy_if > | sptr |
static sptr | make (const std::string &addr, const std::string &port, const zero_copy_xport_params &default_buff_args, udp_zero_copy::buff_params &buff_params_out, const device_addr_t &hints=device_addr_t()) |
Public Member Functions inherited from uhd::transport::zero_copy_if | |
virtual | ~zero_copy_if () |
virtual managed_recv_buffer::sptr | get_recv_buff (double timeout=0.1)=0 |
virtual size_t | get_num_recv_frames (void) const =0 |
virtual size_t | get_recv_frame_size (void) const =0 |
virtual managed_send_buffer::sptr | get_send_buff (double timeout=0.1)=0 |
virtual size_t | get_num_send_frames (void) const =0 |
virtual size_t | get_send_frame_size (void) const =0 |
A zero copy udp transport provides an efficient way to handle data. by avoiding the extra copy when recv() or send() is called on the socket. Rather, the zero copy transport gives the caller memory references. The caller informs the transport when it is finished with the reference.
On linux systems, the zero copy transport can use a kernel packet ring. If no platform specific solution is available, make returns a boost asio implementation that wraps the functionality around a standard send/recv calls.
typedef boost::shared_ptr<udp_zero_copy> uhd::transport::udp_zero_copy::sptr |
Make a new zero copy udp transport: This transport is for sending and receiving between this host and a single endpoint. The primary usage for this transport will be data transactions. The underlying implementation is fast and platform specific.
addr | a string representing the destination address | |
port | a string representing the destination port | |
default_buff_args | Default values for frame sizes and num frames | |
[out] | buff_params_out | Returns the actual buffer sizes |
hints | optional parameters to pass to the underlying transport |
