uhd::convert Namespace Reference
Classes
class  converter
 A conversion class that implements a conversion from inputs -> outputs. More...
struct  id_type
 Identify a conversion routine in the registry. More...
Typedefs
typedef boost::function< converter::sptr(void)> function_type
 Conversion factory function typedef. More...
typedef int priority_type
 Priority of conversion routines. More...
Functions
UHD_API bool operator== (const id_type &, const id_type &)
 Implement equality_comparable interface. More...
UHD_API void register_converter (const id_type &id, const function_type &fcn, const priority_type prio)
UHD_API function_type get_converter (const id_type &id, const priority_type prio=-1)
UHD_API void register_bytes_per_item (const std::string &format, const size_t size)
UHD_API size_t get_bytes_per_item (const std::string &format)
 Convert an item format to a size in bytes. More...
Typedef Documentation
◆ function_type
typedef boost::function<converter::sptr(void)> uhd::convert::function_type
◆ priority_type
Function Documentation
◆ get_bytes_per_item()
UHD_API size_t uhd::convert::get_bytes_per_item ( const std::string &  format)
◆ get_converter()
UHD_API function_type uhd::convert::get_converter ( const id_type &  id,
const priority_type  prio = -1
Get a converter factory function.
ididentify the conversion
priothe desired prio or -1 for best
the converter factory function
◆ operator==()
UHD_API bool uhd::convert::operator== ( const id_type &  ,
const id_type &
◆ register_bytes_per_item()
UHD_API void uhd::convert::register_bytes_per_item ( const std::string &  format,
const size_t  size
Register the size of a particular item.
formatthe item format
sizethe size in bytes
◆ register_converter()
UHD_API void uhd::convert::register_converter ( const id_type &  id,
const function_type &  fcn,
Register a converter function.
Converters with higher priority are given preference.
fcnmakes a new converter
priothe function priority
