18 #ifndef INCLUDED_UHD_UTILS_SOFT_REGISTER_HPP    19 #define INCLUDED_UHD_UTILS_SOFT_REGISTER_HPP    21 #include <boost/cstdint.hpp>    22 #include <boost/noncopyable.hpp>    26 #include <boost/thread/mutex.hpp>    27 #include <boost/thread/locks.hpp>    28 #include <boost/unordered_map.hpp>    29 #include <boost/tokenizer.hpp>    30 #include <boost/foreach.hpp>    31 #include <boost/lexical_cast.hpp>    52 #define UHD_DEFINE_SOFT_REG_FIELD(name, width, shift) \    53     static const uhd::soft_reg_field_t name = (((shift & 0xFF) << 8) | (width & 0xFF))    63     return __builtin_expect(expr,
true);
    73     return __builtin_expect(expr,
false);
    88 namespace soft_reg_field {
    89     inline size_t width(
const soft_reg_field_t field) {
    90         return (field & 0xFF);
    93     inline size_t shift(
    94         return ((field >> 8) & 0xFF);
    97     template<
typename data_t>
    98     inline size_t mask(
    99         static const data_t ONE =
static_cast<data_t
>(1);
   104             return ((ONE<<
width(field))-ONE)<<
shift(field);
   106             return (0-ONE)<<
shift(field);
   114     virtual void initialize(
wb_iface& iface,
bool sync =
false) = 0;
   115     virtual void flush() = 0;
   116     virtual void refresh() = 0;
   117     virtual size_t get_bitwidth() = 0;
   118     virtual bool is_readable() = 0;
   119     virtual bool is_writable() = 0;
   124     template <
typename soft_reg_t>
   126         soft_reg_t* ptr =
dynamic_cast<soft_reg_t*
   142 template<
typename reg_data_t,
bool readable,
bool writable>
   145     typedef boost::shared_ptr< soft_register_t<reg_data_t, readable, writable> >
sptr;
   157         _iface(NULL), _wr_addr(wr_addr), _rd_addr(rd_addr), _soft_copy(0), _flush_mode(mode)
   167         _iface(NULL), _wr_addr(addr), _rd_addr(addr), _soft_copy(0), _flush_mode(mode)
   180         if (sync && writable) flush();
   181         if (sync && readable) refresh();
   189     inline void set(
const soft_reg_field_t field,
const reg_data_t value)
   191         _soft_copy = (_soft_copy & ~soft_reg_field::mask<reg_data_t>(field)) |
   192                      ((value << soft_reg_field::shift(field)) & soft_reg_field::mask<reg_data_t>(field));
   199     inline reg_data_t
get(
   209         if (writable && _iface) {
   213             if (_flush_mode == ALWAYS_FLUSH || _soft_copy.is_dirty()) {
   214                 if (get_bitwidth() <= 16) {
   215                     _iface->poke16(_wr_addr, static_cast<boost::uint16_t>(_soft_copy));
   216                 }
else if (get_bitwidth() <= 32) {
   217                     _iface->poke32(_wr_addr, static_cast<boost::uint32_t>(_soft_copy));
   218                 }
else if (get_bitwidth() <= 64) {
   219                     _iface->poke64(_wr_addr, static_cast<boost::uint64_t>(_soft_copy));
   223                 _soft_copy.mark_clean();
   235         if (readable && _iface) {
   236             if (get_bitwidth() <= 16) {
   237                 _soft_copy =
static_cast<reg_data_t
>(_iface->peek16(_rd_addr));
   238             }
   239                 _soft_copy =
>(_iface->peek32(_rd_addr));
   240             }
   241                 _soft_copy =
>(_iface->peek64(_rd_addr));
   245             _soft_copy.mark_clean();
   254     inline void write(
   263     inline reg_data_t
read(
   274         static const size_t BITS_IN_BYTE = 8;
   275         return sizeof(reg_data_t) * BITS_IN_BYTE;
   306 template<
bool readable,
bool writable>
   309     typedef boost::shared_ptr< soft_register_sync_t<reg_data_t, readable, writable> >
sptr;
   315         soft_register_t<reg_data_t, readable, writable>(wr_addr, rd_addr, mode), _mutex()
   326         boost::lock_guard<boost::mutex> lock(_mutex);
   330     inline void set(
   332         boost::lock_guard<boost::mutex> lock(_mutex);
   336     inline reg_data_t
get(
   338         boost::lock_guard<boost::mutex> lock(_mutex);
   344         boost::lock_guard<boost::mutex> lock(_mutex);
   350         boost::lock_guard<boost::mutex> lock(_mutex);
   354     inline void write(
   356         boost::lock_guard<boost::mutex> lock(_mutex);
   360     inline reg_data_t
read(
   362         boost::lock_guard<boost::mutex> lock(_mutex);
   446     typedef boost::shared_ptr<soft_regmap_accessor_t>
sptr;
   450     virtual std::vector<std::string> enumerate()
const = 0;
   451     virtual const std::string& get_name()
const = 0;
   472     virtual inline const std::string&
get_name()
 const {
return _name; }
   481         boost::lock_guard<boost::mutex> lock(_mutex);
   493         boost::lock_guard<boost::mutex> lock(_mutex);
   505         boost::lock_guard<boost::mutex> lock(_mutex);
   516         regmap_t::const_iterator iter = _regmap.find(name);
   517         if (iter != _regmap.end()) {
   518             return *(iter->second);
   529         std::vector<std::string> temp;
   530         BOOST_FOREACH(
const regmap_t::value_type& reg, _regmap) {
   531             temp.push_back(_name +
"/" + reg.first);
   546         boost::lock_guard<boost::mutex> lock(_mutex);
   547         if (visible == PUBLIC) {
   549             if (not _regmap.insert(regmap_t::value_type(name, ®)).second) {
   553         _reglist.push_back(®);
   557     typedef boost::unordered_map<std::string, soft_register_base*> regmap_t;
   558     typedef std::list<soft_register_base*>                         reglist_t;
   560     const std::string   _name;
   575     typedef boost::shared_ptr<soft_regmap_db_t>
sptr;
   590     const std::string&
get_name()
 const {
return _name; }
   596         boost::lock_guard<boost::mutex> lock(_mutex);
   597         _regmaps.push_back(®map);
   604         boost::lock_guard<boost::mutex> lock(_mutex);
   608             _regmap_dbs.push_back(&db);
   625         std::list<std::string> tokens;
   627             const std::string& node,
   628             boost::tokenizer< boost::char_separator<char> >(path, boost::char_separator<char>(
   630             tokens.push_back(node);
   632         if ((tokens.size() > 2 && tokens.front() == _name) ||
   633             (tokens.size() > 1 && _name ==
   634             if (_name !=
"") tokens.pop_front();
   635             if (tokens.size() == 2) {
   637                     if (regmap->
get_name() == tokens.front()) {
   638                         return regmap->
lookup(tokens.back());
   642             }
else if (not _regmap_dbs.empty()) {
   645                 BOOST_FOREACH(
const std::string& node, tokens) {
   646                     newpath += (
"/" + node);
   651                         return db->
lookup(newpath.substr(1));
   652                     }
catch (std::exception& e) {
   665         std::vector<std::string> paths;
   667             const std::vector<std::string>& regs = regmap->
enumerate();
   668             paths.insert(paths.end(), regs.begin(), regs.end());
   671             const std::vector<std::string>& regs = db->
enumerate();
   672             paths.insert(paths.end(), regs.begin(), regs.end());
   678     typedef std::list<soft_regmap_accessor_t*> db_t;
   680     const std::string   _name;
 void refresh()
Definition: soft_register.hpp:348
void refresh()
Definition: soft_register.hpp:504
size_t width(const soft_reg_field_t field)
Definition: soft_register.hpp:89
void flush()
Definition: soft_register.hpp:207
reg_data_t get(const soft_reg_field_t field)
Definition: soft_register.hpp:199
void initialize(wb_iface &iface, bool sync=false)
Definition: soft_register.hpp:324
Definition: soft_register.hpp:135
bool likely(bool expr)
hint for the branch prediction
Definition: soft_register.hpp:60
soft_reg_flush_mode_t
boost::shared_ptr< soft_register_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:145
Definition: soft_register.hpp:307
Definition: exception.hpp:109
soft_register_t< boost::uint64_t, true, false > soft_reg64_ro_t
Definition: soft_register.hpp:398
soft_regmap_t(const std::string &name)
Definition: soft_register.hpp:466
void write(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:354
soft_register_sync_t< boost::uint16_t, true, false > soft_reg16_ro_sync_t
Definition: soft_register.hpp:387
virtual std::vector< std::string > enumerate() const
Definition: soft_register.hpp:528
soft_register_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:164
size_t mask(const soft_reg_field_t field)
Definition: soft_register.hpp:98
virtual soft_register_base & lookup(const std::string &name) const
Definition: soft_register.hpp:515
void add_to_map(soft_register_base ®, const std::string &name, const visibility_t visible=PRIVATE)
Definition: soft_register.hpp:545
soft_register_t< boost::uint64_t, false, true > soft_reg64_wo_t
Definition: soft_register.hpp:397
soft_register_sync_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:318
bool is_readable()
Definition: soft_register.hpp:281
Definition: exception.hpp:94
reg_data_t read(const soft_reg_field_t field)
Definition: soft_register.hpp:263
Definition: soft_register.hpp:573
soft_register_t< boost::uint32_t, true, false > soft_reg32_ro_t
Definition: soft_register.hpp:391
soft_register_sync_t< boost::uint32_t, true, false > soft_reg32_ro_sync_t
Definition: soft_register.hpp:394
boost::uint32_t wb_addr_type
Definition: wb_iface.hpp:33
soft_register_t< boost::uint16_t, true, false > soft_reg16_ro_t
Definition: soft_register.hpp:384
Definition: soft_register.hpp:664
soft_register_t< boost::uint32_t, false, true > soft_reg32_wo_t
Definition: soft_register.hpp:390
Definition: soft_register.hpp:254
soft_register_sync_t< boost::uint16_t, false, true > soft_reg16_wo_sync_t
Definition: soft_register.hpp:386
Definition: soft_register.hpp:538
soft_regmap_db_t(const std::string &name)
Definition: soft_register.hpp:585
virtual ~soft_regmap_accessor_t()
Definition: soft_register.hpp:448
Definition: soft_register.hpp:143
Definition: soft_register.hpp:360
soft_regmap_db_t()
Definition: soft_register.hpp:580
boost::uint32_t soft_reg_field_t
Definition: soft_register.hpp:86
static soft_reg_t & cast(soft_register_base ®)
Definition: soft_register.hpp:125
virtual std::vector< std::string > enumerate() const =0
virtual soft_register_base & lookup(const std::string &path) const =0
virtual ~soft_register_base()
Definition: soft_register.hpp:112
void flush()
Definition: soft_register.hpp:492
visibility_t
Definition: soft_register.hpp:537
soft_register_sync_t< boost::uint16_t, true, true > soft_reg16_rw_sync_t
Definition: soft_register.hpp:388
soft_register_t< boost::uint16_t, false, true > soft_reg16_wo_t
Definition: soft_register.hpp:383
boost::shared_ptr< soft_register_sync_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:309
Definition: soft_register.hpp:480
virtual const std::string & get_name() const =0
virtual ~soft_regmap_t()
Definition: soft_register.hpp:467
soft_register_sync_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:311
boost::shared_ptr< soft_regmap_accessor_t > sptr
Definition: soft_register.hpp:446
Definition: soft_register.hpp:444
size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:93
soft_register_sync_t< boost::uint32_t, true, true > soft_reg32_rw_sync_t
Definition: soft_register.hpp:395
soft_register_sync_t< boost::uint32_t, false, true > soft_reg32_wo_sync_t
Definition: soft_register.hpp:393
soft_register_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:153
boost::shared_ptr< soft_regmap_db_t > sptr
Definition: soft_register.hpp:575
Definition: soft_register.hpp:464
Definition: soft_register.hpp:472
Definition: soft_register.hpp:110
Definition: exception.hpp:52
soft_register_sync_t< boost::uint64_t, true, true > soft_reg64_rw_sync_t
Definition: soft_register.hpp:402
Definition: config.h:66
void add(soft_regmap_t ®map)
Definition: soft_register.hpp:595
void set(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:189
void flush()
Definition: soft_register.hpp:342
Definition: soft_register.hpp:272
Definition: soft_register.hpp:590
bool unlikely(bool expr)
Definition: soft_register.hpp:70
soft_register_t< boost::uint32_t, true, true > soft_reg32_rw_t
Definition: soft_register.hpp:392
soft_register_t< boost::uint16_t, true, true > soft_reg16_rw_t
Definition: soft_register.hpp:385
soft_register_t< boost::uint64_t, true, true > soft_reg64_rw_t
Definition: soft_register.hpp:399
Definition: exception.hpp:80
Definition: soft_register.hpp:175
void add(soft_regmap_db_t &db)
Definition: soft_register.hpp:603
virtual void initialize(wb_iface &iface, bool sync=false)=0
Definition: soft_register.hpp:622
void refresh()
Definition: soft_register.hpp:233
soft_register_sync_t< boost::uint64_t, true, false > soft_reg64_ro_sync_t
Definition: soft_register.hpp:401
soft_register_sync_t< boost::uint64_t, false, true > soft_reg64_wo_sync_t
Definition: soft_register.hpp:400
bool is_writable()
Definition: soft_register.hpp:289
Definition: wb_iface.hpp:29
