Functions | |
| UHD_API uhd_error | uhd_set_thread_priority (float priority, bool realtime) |
Set the scheduling priority on the current thread.
A new thread or calling process should make this call with the defailts this to enable realtime scheduling.
A priority of zero corresponds to normal priority. Positive priority values are higher than normal. Negative priority values are lower than normal.
| priority | a value between -1 and 1 |
| realtime | true to use realtime mode |
