#include <uhd/device.hpp>
 Public Types | |
| enum | device_filter_t { ANY, USRP, CLOCK } |
| Device type, used as a filter in make.  More... | |
| typedef boost::shared_ptr< device > | sptr |
| typedef boost::function< device_addrs_t(const device_addr_t &)> | find_t |
| typedef boost::function< sptr(const device_addr_t &)> | make_t |
| virtual | ~device (void)=0 |
| virtual rx_streamer::sptr | get_rx_stream (const stream_args_t &args)=0 |
| Make a new receive streamer from the streamer arguments.  More... | |
| virtual tx_streamer::sptr | get_tx_stream (const stream_args_t &args)=0 |
| Make a new transmit streamer from the streamer arguments.  More... | |
| uhd::property_tree::sptr | get_tree (void) const |
| Get access to the underlying property structure.  More... | |
| device_filter_t | get_device_type () const |
| Get device type.  More... | |
| static void | register_device (const find_t &find, const make_t &make, const device_filter_t filter) |
| static device_addrs_t | find (const device_addr_t &hint, device_filter_t filter=ANY) |
| Find devices attached to the host.  More... | |
| static sptr | make (const device_addr_t &hint, device_filter_t filter=ANY, size_t which=0) |
| Create a new device from the device address hint.  More... | |
Protected Attributes | |
| uhd::property_tree::sptr | _tree |
| device_filter_t | _type |
The device interface represents the hardware. The API allows for discovery, configuration, and streaming.
| typedef boost::function<device_addrs_t(const device_addr_t &)> uhd::device::find_t |
| typedef boost::function<sptr(const device_addr_t &)> uhd::device::make_t |
| typedef boost::shared_ptr<device> uhd::device::sptr |
The hint device address should be used to narrow down the search to particular transport types and/or transport arguments.
| hint | a partially (or fully) filled in device address |
| filter | an optional filter to exclude USRP or clock devices |
| device_filter_t uhd::device::get_device_type | ( | ) | const |
Get device type.
Note: There can always only be one streamer. When calling get_rx_stream() a second time, the first streamer must be destroyed beforehand.
| uhd::property_tree::sptr uhd::device::get_tree | ( | void | ) | const |
Note: There can always only be one streamer. When calling get_tx_stream() a second time, the first streamer must be destroyed beforehand.
The method will go through the registered device types and pick one of the discovered devices.
By default, the first result will be used to create a new device. Use the which parameter as an index into the list of results.
| which | which address to use when multiple are found |
Register a device into the discovery and factory system.
| find | a function that discovers devices |
| make | a factory function that makes a device |
| filter | include only USRP devices, clock devices, or both |
  protected |
  protected |
