#include <uhd/utils/msg_task.hpp>
◆ msg_payload_t
◆ msg_type_t
◆ sptr
◆ task_fcn_type
◆ ~msg_task()
| virtual uhd::msg_task::~msg_task |
void |
◆ buff_to_vector()
| static std::vector<boost::uint8_t> uhd::msg_task::buff_to_vector |
boost::uint8_t * |
p, |
size_t |
n |
inlinestatic |
◆ get_msg_from_dump_queue()
| virtual msg_payload_t uhd::msg_task::get_msg_from_dump_queue |
boost::uint32_t |
sid | ) |
◆ make()
- The blocking call is interruptible.
- The task polls the interrupt condition.
- Parameters
| task_fcn | the task callback function |
- Returns
- a new task object
