Classes | |
| struct | uhd_subdev_spec_pair_t |
| Subdevice specification.  More... | |
Typedefs | |
| typedef struct uhd_subdev_spec_t * | uhd_subdev_spec_handle |
| A C-level interface for working with a list of subdevice specifications.  More... | |
Functions | |
| UHD_API uhd_error | uhd_subdev_spec_pair_free (uhd_subdev_spec_pair_t *subdev_spec_pair) |
| Safely destroy any memory created in the generation of a uhd_subdev_spec_pair_t.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_pairs_equal (const uhd_subdev_spec_pair_t *first, const uhd_subdev_spec_pair_t *second, bool *result_out) |
| Check to see if two subdevice specifications are equal.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_make (uhd_subdev_spec_handle *h, const char *markup) |
| Create a handle for a list of subdevice specifications.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_free (uhd_subdev_spec_handle *h) |
| Safely destroy a subdevice specification handle.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_size (uhd_subdev_spec_handle h, size_t *size_out) |
| Check how many subdevice specifications are in this list.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_push_back (uhd_subdev_spec_handle h, const char *markup) |
| Add a subdevice specification to this list.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_at (uhd_subdev_spec_handle h, size_t num, uhd_subdev_spec_pair_t *subdev_spec_pair_out) |
| Get the subdevice specification at the given index.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_to_pp_string (uhd_subdev_spec_handle h, char *pp_string_out, size_t strbuffer_len) |
| Get a string representation of the given list.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_to_string (uhd_subdev_spec_handle h, char *string_out, size_t strbuffer_len) |
| Get a markup string representation of the given list.  More... | |
| UHD_API uhd_error | uhd_subdev_spec_last_error (uhd_subdev_spec_handle h, char *error_out, size_t strbuffer_len) |
| Get the last error recorded by the given handle.  More... | |
| typedef struct uhd_subdev_spec_t* uhd_subdev_spec_handle |
See uhd::usrp::subdev_spec_t for more details.
NOTE: Using a handle before passing it into uhd_subdev_spec_make() will result in undefined behavior.
| UHD_API uhd_error uhd_subdev_spec_at | ( | uhd_subdev_spec_handle | h, |
| size_t | num, | ||
| uhd_subdev_spec_pair_t * | subdev_spec_pair_out | ||
| UHD_API uhd_error uhd_subdev_spec_free | ( | uhd_subdev_spec_handle * | h | ) |
| UHD_API uhd_error uhd_subdev_spec_last_error | ( | uhd_subdev_spec_handle | h, |
| char * | error_out, | ||
| size_t | strbuffer_len | ||
| UHD_API uhd_error uhd_subdev_spec_make | ( | uhd_subdev_spec_handle * | h, |
| const char * | markup | ||
| UHD_API uhd_error uhd_subdev_spec_pair_free | ( | uhd_subdev_spec_pair_t * | subdev_spec_pair | ) |
| UHD_API uhd_error uhd_subdev_spec_pairs_equal | ( | const uhd_subdev_spec_pair_t * | first, |
| const uhd_subdev_spec_pair_t * | second, | ||
| bool * | result_out | ||
| UHD_API uhd_error uhd_subdev_spec_push_back | ( | uhd_subdev_spec_handle | h, |
| UHD_API uhd_error uhd_subdev_spec_size | ( | uhd_subdev_spec_handle | h, |
| size_t * | size_out | ||
| UHD_API uhd_error uhd_subdev_spec_to_pp_string | ( | uhd_subdev_spec_handle | h, |
| char * | pp_string_out, | ||
| UHD_API uhd_error uhd_subdev_spec_to_string | ( | uhd_subdev_spec_handle | h, |
| char * | string_out, | ||
