#include <uhd/types/dict.hpp>
|   | dict (void) |
| template<typename InputIterator >  |
|   | dict (InputIterator first, InputIterator last) |
| std::size_t  | size (void) const |
| std::vector< Key >  | keys (void) const |
| std::vector< Val >  | vals (void) const |
| bool  | has_key (const Key &key) const |
| const Val &  | get (const Key &key, const Val &other) const |
| const Val &  | get (const Key &key) const |
| void  | set (const Key &key, const Val &val) |
| const Val &  | operator[] (const Key &key) const |
| Val &  | operator[] (const Key &key) |
| Val  | pop (const Key &key) |
| void  | update (const dict< Key, Val > &new_dict, bool fail_on_conflict=true) |
template<typename Key, typename Val>
class uhd::dict< Key, Val >
A templated dictionary class with a python-like interface.
◆ dict() [1/2]
template<typename Key , typename Val >
Create a new empty dictionary.
◆ dict() [2/2]
          | uhd::dict< Key, Val >::dict  |
          InputIterator  |
          first,  |
          InputIterator  |
          last  |
Input iterator constructor: Makes boost::assign::map_list_of work.
- Parameters
    | first | the begin iterator  |
    | last | the end iterator  |
◆ get() [1/2]
          | const Val & uhd::dict< Key, Val >::get  |
          const Key &  |
          key,  |
          const Val &  |
          other  |
           |  const |
Get a value in the dict or default.
- Parameters
    | key | the key to look for  |
    | other | use if key not found  |
- Returns
 - the value or default
◆ get() [2/2]
          const Key &  |
          key | ) |
           const |
Get a value in the dict or throw.
- Parameters
- Returns
◆ has_key()
template<typename Key, typename Val >
          | bool uhd::dict< Key, Val >::has_key  |
          const Key &  |
          key | ) |
           const |
Does the dictionary contain this key?
- Parameters
- Returns
 - true if found
◆ keys()
          | std::vector< Key > uhd::dict< Key, Val >::keys  |
          void  |
           const |
Get a list of the keys in this dict. Key order depends on insertion precedence.
- Returns
 - vector of keys
◆ operator[]() [1/2]
          | const Val & uhd::dict< Key, Val >::operator[]  |
          const Key &  |
          key | ) |
           const |
Get a value for the given key if it exists. If the key is not found throw an error.
- Parameters
- Returns
 - the value at the key
- Exceptions
    | an | exception when not found  |
◆ operator[]() [2/2]
          const Key &  |
          key | ) |
Set a value for the given key, however, in reality it really returns a reference which can be assigned to.
- Parameters
- Returns
 - a reference to the value
◆ pop()
          | Val uhd::dict< Key, Val >::pop  |
          const Key &  |
          key | ) |
Pop an item out of the dictionary.
- Parameters
- Returns
 - the value of the item
- Exceptions
          | void uhd::dict< Key, Val >::set  |
          const Key &  |
          key,  |
          const Val &  |
          val  |
Set a value in the dict at the key.
- Parameters
    | key | the key to set at  |
    | val | the value to set  |
◆ size()
          | std::size_t uhd::dict< Key, Val >::size  |
          void  |
           const |
Get the number of elements in this dict.
- Returns
 - the number of elements
◆ update()
          | void uhd::dict< Key, Val >::update  |
          const dict< Key, Val > &  |
          new_dict,  |
          bool  |
          fail_on_conflict = true  |
Update this dictionary with values from another.
Basically, this copies all the key/value pairs from new_dict into this dict. When the key is already present in the current dict, it either overwrites the current value (if fail_on_conflict is false) or it throws (if fail_on_conflict is true and the values differ).
With the exception of fail_on_conflict, this behaves analogously to Python's dict.update() method.
- Parameters
    | new_dict | The arguments to copy.  |
    | fail_on_conflict | If true, throws.  |
- Exceptions
◆ vals()
          | std::vector< Val > uhd::dict< Key, Val >::vals  |
          void  |
           const |
Get a list of the values in this dict. Value order depends on insertion precedence.
- Returns
 - vector of values
