USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
dboard_eeprom.h File Reference
#include <uhd/config.h>
#include <uhd/error.h>
Typedefs
typedef struct uhd_dboard_eeprom_t * uhd_dboard_eeprom_handle
 A C-level interface for interacting with a daughterboard EEPROM. More...
Functions
UHD_API uhd_error uhd_dboard_eeprom_make (uhd_dboard_eeprom_handle *h)
 Create handle for a USRP daughterboard EEPROM. More...
UHD_API uhd_error uhd_dboard_eeprom_free (uhd_dboard_eeprom_handle *h)
 Safely destroy the given handle. More...
UHD_API uhd_error uhd_dboard_eeprom_get_id (uhd_dboard_eeprom_handle h, char *id_out, size_t strbuffer_len)
 Get the ID associated with the given daughterboard as a string hex representation. More...
UHD_API uhd_error uhd_dboard_eeprom_set_id (uhd_dboard_eeprom_handle h, const char *id)
 Set the daughterboard ID using a string hex representation. More...
UHD_API uhd_error uhd_dboard_eeprom_get_serial (uhd_dboard_eeprom_handle h, char *serial_out, size_t strbuffer_len)
 Get the daughterboard's serial. More...
UHD_API uhd_error uhd_dboard_eeprom_set_serial (uhd_dboard_eeprom_handle h, const char *serial)
 Set the daughterboard's serial. More...
UHD_API uhd_error uhd_dboard_eeprom_get_revision (uhd_dboard_eeprom_handle h, int *revision_out)
 Get the daughterboard's revision (not always present) More...
UHD_API uhd_error uhd_dboard_eeprom_set_revision (uhd_dboard_eeprom_handle h, int revision)
 Set the daughterboard's revision. More...
UHD_API uhd_error uhd_dboard_eeprom_last_error (uhd_dboard_eeprom_handle h, char *error_out, size_t strbuffer_len)
 Get the last error reported by the handle. More...
Typedef Documentation
◆ uhd_dboard_eeprom_handle
typedef struct uhd_dboard_eeprom_t* uhd_dboard_eeprom_handle
See uhd::usrp::dboard_eeprom_t for more details.
NOTE: Using a handle before passing it into uhd_dboard_eeprom_make() will result in undefined behavior.
Function Documentation
◆ uhd_dboard_eeprom_free()
UHD_API uhd_error uhd_dboard_eeprom_free ( uhd_dboard_eeprom_handle h)
◆ uhd_dboard_eeprom_get_id()
UHD_API uhd_error uhd_dboard_eeprom_get_id ( uhd_dboard_eeprom_handle  h,
char *  id_out,
◆ uhd_dboard_eeprom_get_revision()
UHD_API uhd_error uhd_dboard_eeprom_get_revision ( uhd_dboard_eeprom_handle  h,
int *  revision_out
◆ uhd_dboard_eeprom_get_serial()
UHD_API uhd_error uhd_dboard_eeprom_get_serial ( uhd_dboard_eeprom_handle  h,
char *  serial_out,
◆ uhd_dboard_eeprom_last_error()
UHD_API uhd_error uhd_dboard_eeprom_last_error ( uhd_dboard_eeprom_handle  h,
char *  error_out,
◆ uhd_dboard_eeprom_make()
UHD_API uhd_error uhd_dboard_eeprom_make ( uhd_dboard_eeprom_handle h)
◆ uhd_dboard_eeprom_set_id()
UHD_API uhd_error uhd_dboard_eeprom_set_id ( uhd_dboard_eeprom_handle  h,
const char *  id
◆ uhd_dboard_eeprom_set_revision()
UHD_API uhd_error uhd_dboard_eeprom_set_revision ( uhd_dboard_eeprom_handle  h,
int  revision
◆ uhd_dboard_eeprom_set_serial()
UHD_API uhd_error uhd_dboard_eeprom_set_serial ( uhd_dboard_eeprom_handle  h,
const char *  serial
