USRP Hardware Driver and USRP Manual  Version: 003.009.002-0-gf18abe54
uhd::transport::vrt::chdr Namespace Reference
CVITA/CHDR related function. More...
Functions
UHD_API void if_hdr_pack_be (boost::uint32_t *packet_buff, if_packet_info_t &if_packet_info)
UHD_API void if_hdr_unpack_be (const boost::uint32_t *packet_buff, if_packet_info_t &if_packet_info)
UHD_API void if_hdr_pack_le (boost::uint32_t *packet_buff, if_packet_info_t &if_packet_info)
UHD_API void if_hdr_unpack_le (const boost::uint32_t *packet_buff, if_packet_info_t &if_packet_info)
See CVITA (CHDR) for details on the CVITA/CHDR protocol.
All packers take the host format into account. Choose the _le functions if the transport uses little endian format (e.g. PCIe) and the _be functions if the transport uses big endian format (e.g. Ethernet).
Note 1: All packers assume there to be enough space at the address provided by packet_buff. See also Packing contract.
Note 2: All these packers assume the following options without checking them:
  • if_packet_info.link_type == LINK_TYPE_CHDR
  • if_packet_info.has_cid == false
  • if_packet_info.has_sid == true
  • if_packet_info.has_tsi == false
  • if_packet_info.has_tlr == false This relaxes some of Packing contract, but adds the additional constraint that the input data must be CHDR.
In the unpacker, these values will be set accordingly.
Function Documentation
◆ if_hdr_pack_be()
UHD_API void uhd::transport::vrt::chdr::if_hdr_pack_be ( boost::uint32_t *  packet_buff,
if_packet_info_t if_packet_info
Pack a CHDR header from metadata (big endian format).
See Packing contract, but link_type is assumed to be LINK_TYPE_CHDR.
packet_buffmemory to write the packed vrt header
if_packet_infothe if packet info (read/write)
◆ if_hdr_pack_le()
UHD_API void uhd::transport::vrt::chdr::if_hdr_pack_le ( boost::uint32_t *  packet_buff,
Pack a CHDR header from metadata (little endian format).
◆ if_hdr_unpack_be()
UHD_API void uhd::transport::vrt::chdr::if_hdr_unpack_be ( const boost::uint32_t *  packet_buff,
Unpack a CHDR header to metadata (big endian format).
See Unpacking contract, but link_type is assumed to be LINK_TYPE_CHDR.
packet_buffmemory to read the packed vrt header
◆ if_hdr_unpack_le()
UHD_API void uhd::transport::vrt::chdr::if_hdr_unpack_le ( const boost::uint32_t *  packet_buff,
Unpack a CHDR header to metadata (little endian format).
