uhd::sid_t Class Reference
Represents a stream ID (SID). More...
#include <uhd/types/sid.hpp>
 sid_t ()
 Create an unset SID. More...
 sid_t (boost::uint32_t sid)
 Create a sid_t object from a 32-Bit SID value. More...
 sid_t (boost::uint8_t src_addr, boost::uint8_t src_ep, boost::uint8_t dst_addr, boost::uint8_t dst_ep)
 Create a sid_t object from its four components. More...
 sid_t (const std::string &)
 Convert a string representation of a SID into its numerical representation. More...
std::string to_pp_string () const
 Return a decimal string representation of the SID. More...
std::string to_pp_string_hex () const
 Return a hexadecimal string representation of the SID. More...
bool is_set () const
 Returns true if this actually holds a valid SID. More...
UHD_INLINE boost::uint32_t get () const
 Alias for get_sid() More...
UHD_INLINE boost::uint32_t get_sid () const
 Returns a 32-Bit representation of the SID if set, or zero otherwise. More...
UHD_INLINE boost::uint32_t get_src () const
 Return the 16-bit source address of this SID. More...
UHD_INLINE boost::uint32_t get_dst () const
 Return the 16-bit destination address of this SID. More...
UHD_INLINE boost::uint32_t get_src_addr () const
 Return 8-bit address of the source. More...
UHD_INLINE boost::uint32_t get_src_endpoint () const
 Return endpoint of the source. More...
UHD_INLINE boost::uint32_t get_src_xbarport () const
 Return crossbar port of the source. More...
UHD_INLINE boost::uint32_t get_src_blockport () const
 Return block port of the source. More...
UHD_INLINE boost::uint32_t get_dst_addr () const
 Return 8-bit address of the destination. More...
UHD_INLINE boost::uint32_t get_dst_endpoint () const
 Return endpoint of the destination. More...
UHD_INLINE boost::uint32_t get_dst_xbarport () const
UHD_INLINE boost::uint32_t get_dst_blockport () const
void set (boost::uint32_t new_sid)
 Alias for set_sid() More...
void set_from_str (const std::string &)
 Convert a string representation of a SID into a numerical one. More...
void set_sid (boost::uint32_t new_sid)
void set_src (boost::uint32_t new_addr)
 Set the source address of this SID. More...
void set_dst (boost::uint32_t new_addr)
 Set the destination address of this SID. More...
void set_src_addr (boost::uint32_t new_addr)
void set_src_endpoint (boost::uint32_t new_addr)
void set_dst_addr (boost::uint32_t new_addr)
void set_dst_endpoint (boost::uint32_t new_addr)
void set_dst_xbarport (boost::uint32_t new_xbarport)
void set_dst_blockport (boost::uint32_t new_blockport)
sid_t reversed ()
 Swaps dst and src address and returns the new SID. More...
void reverse ()
 Swaps dst and src in-place. More...
sid_t operator= (boost::uint32_t new_sid)
sid_t operator= (sid_t &sid)
sid_t operator= (const std::string &sid_str)
bool operator== (const sid_t &sid) const
bool operator== (boost::uint32_t sid) const
bool operator== (const std::string &sid_str) const
 operator boost::uint32_t () const
 If the SID is not set, always returns zero. More...
 operator bool () const
A stream ID (SID) is an identifier for data. It is a 32-Bit value which consistst of 16 Bits for the source address and 16 Bits for the destination address. Every address is split into two parts: The address, which identifies the device used, and the endpoint, which identifies a specific object inside the given device (e.g., a block). Note: In the case where there are several crossbars on a single device, each crossbar gets its own address. Both address and endpoint are 8 bits in length. If a 16-bit address is required, we use the combination of the 8-bit address and the 8-bit endpoint.
String Representation
The string representation of a SID is of the form
2.3>0.6
The '>' symbol shows the direction, so in this case, data is flowing from address 2.3 to 0.6.
As a convention, ':' is used instead of '.' when giving the SID in hexadecimal numbers, and two characters are used for each address part. As an example, the following two SIDs are identical:
2.3>0.16 (decimal)
02:03>00:10 (hexadecimal)
The format is: SRC_ADDRESS.SRC_ENDPOINT>DST_ADDRESS.DST_ENDPOINT
Block Ports
In the special case where a block on a crossbar is addressed, the endpoint is further split up into two parts of four bits each: The first four bits specify the port number on the crossbar, whereas the lower four bits represent the block port. As an example, consider the following SID, given in hexadecimal:
00:10>02:A1
In this example, assume data is flowing from the host computer to an X300. The crossbar address is 02. The endpoint is A1, which means we are accessing a block on crossbar port A (the tenth port), and are addressing block port 1.
◆ sid_t() [1/4]
uhd::sid_t::sid_t ( )
◆ sid_t() [2/4]
uhd::sid_t::sid_t ( boost::uint32_t  sid)
◆ sid_t() [3/4]
uhd::sid_t::sid_t ( boost::uint8_t  src_addr,
◆ sid_t() [4/4]
uhd::sid_t::sid_t ( const std::string &  )
UHD_INLINE boost::uint32_t uhd::sid_t::get ( void  ) const
Alias for get_sid()
◆ get_dst()
UHD_INLINE boost::uint32_t uhd::sid_t::get_dst ( ) const
◆ get_dst_addr()
UHD_INLINE boost::uint32_t uhd::sid_t::get_dst_addr ( ) const
◆ get_dst_blockport()
UHD_INLINE boost::uint32_t uhd::sid_t::get_dst_blockport ( ) const
◆ get_dst_endpoint()
UHD_INLINE boost::uint32_t uhd::sid_t::get_dst_endpoint ( ) const
◆ get_dst_xbarport()
UHD_INLINE boost::uint32_t uhd::sid_t::get_dst_xbarport ( ) const
◆ get_sid()
UHD_INLINE boost::uint32_t uhd::sid_t::get_sid ( ) const
◆ get_src()
UHD_INLINE boost::uint32_t uhd::sid_t::get_src ( ) const
◆ get_src_addr()
UHD_INLINE boost::uint32_t uhd::sid_t::get_src_addr ( ) const
◆ get_src_blockport()
UHD_INLINE boost::uint32_t uhd::sid_t::get_src_blockport ( ) const
◆ get_src_endpoint()
UHD_INLINE boost::uint32_t uhd::sid_t::get_src_endpoint ( ) const
◆ get_src_xbarport()
UHD_INLINE boost::uint32_t uhd::sid_t::get_src_xbarport ( ) const
◆ is_set()
bool uhd::sid_t::is_set ( ) const
◆ operator bool()
uhd::sid_t::operator bool ( ) const
◆ operator boost::uint32_t()
uhd::sid_t::operator boost::uint32_t ( ) const
◆ operator=() [1/3]
sid_t uhd::sid_t::operator= ( boost::uint32_t  new_sid)
◆ operator=() [2/3]
sid_t uhd::sid_t::operator= ( sid_t sid)
◆ operator=() [3/3]
sid_t uhd::sid_t::operator= ( const std::string &  sid_str)
◆ operator==() [1/3]
bool uhd::sid_t::operator== ( const sid_t sid) const
◆ operator==() [2/3]
bool uhd::sid_t::operator== ( boost::uint32_t  sid) const
◆ operator==() [3/3]
bool uhd::sid_t::operator== ( const std::string &  sid_str) const
◆ reverse()
void uhd::sid_t::reverse ( )
◆ reversed()
sid_t uhd::sid_t::reversed ( )
void uhd::sid_t::set ( boost::uint32_t  new_sid)
Alias for set_sid()
◆ set_dst()
void uhd::sid_t::set_dst ( boost::uint32_t  new_addr)
◆ set_dst_addr()
void uhd::sid_t::set_dst_addr ( boost::uint32_t  new_addr)
◆ set_dst_blockport()
void uhd::sid_t::set_dst_blockport ( boost::uint32_t  new_blockport)
◆ set_dst_endpoint()
void uhd::sid_t::set_dst_endpoint ( boost::uint32_t  new_addr)
◆ set_dst_xbarport()
void uhd::sid_t::set_dst_xbarport ( boost::uint32_t  new_xbarport)
◆ set_from_str()
void uhd::sid_t::set_from_str ( const std::string &  )
◆ set_sid()
void uhd::sid_t::set_sid ( boost::uint32_t  new_sid)
◆ set_src()
void uhd::sid_t::set_src ( boost::uint32_t  new_addr)
◆ set_src_addr()
void uhd::sid_t::set_src_addr ( boost::uint32_t  new_addr)
◆ set_src_endpoint()
void uhd::sid_t::set_src_endpoint ( boost::uint32_t  new_addr)
◆ to_pp_string()
std::string uhd::sid_t::to_pp_string ( ) const
◆ to_pp_string_hex()
std::string uhd::sid_t::to_pp_string_hex ( ) const
