#include <stdlib.h>Go to the source code of this file.
Enumerations | |
| enum | uhd_error {  UHD_ERROR_NONE = 0, UHD_ERROR_INVALID_DEVICE = 1, UHD_ERROR_INDEX = 10, UHD_ERROR_KEY = 11, UHD_ERROR_NOT_IMPLEMENTED = 20, UHD_ERROR_USB = 21, UHD_ERROR_IO = 30, UHD_ERROR_OS = 31, UHD_ERROR_ASSERTION = 40, UHD_ERROR_LOOKUP = 41, UHD_ERROR_TYPE = 42, UHD_ERROR_VALUE = 43, UHD_ERROR_RUNTIME = 44, UHD_ERROR_ENVIRONMENT = 45, UHD_ERROR_SYSTEM = 46, UHD_ERROR_EXCEPT = 47, UHD_ERROR_BOOSTEXCEPT = 60, UHD_ERROR_STDEXCEPT = 70, UHD_ERROR_UNKNOWN = 100 }  |
| UHD error codes.  More... | |
Functions | |
| uhd_error | uhd_get_last_error (char *error_out, size_t strbuffer_len) |
| Return the last error string reported by UHD.  More... | |
| enum uhd_error |
UHD error codes.
Each error code corresponds to a specific uhd::exception, with extra codes corresponding to a boost::exception, std::exception, and a catch-all for everything else. When an internal C++ function throws an exception, UHD converts it to one of these error codes to return on the C level.
| Enumerator | |
| UHD_ERROR_NONE | No error thrown.  |
| UHD_ERROR_INVALID_DEVICE | Invalid device arguments.  |
| UHD_ERROR_INDEX | See uhd::index_error.  |
| UHD_ERROR_KEY | See uhd::key_error.  |
| UHD_ERROR_NOT_IMPLEMENTED | |
| UHD_ERROR_USB | See uhd::usb_error.  |
| UHD_ERROR_IO | See uhd::io_error.  |
| UHD_ERROR_OS | See uhd::os_error.  |
| UHD_ERROR_ASSERTION | See uhd::assertion_error.  |
| UHD_ERROR_LOOKUP | See uhd::lookup_error.  |
| UHD_ERROR_TYPE | See uhd::type_error.  |
| UHD_ERROR_VALUE | See uhd::value_error.  |
| UHD_ERROR_RUNTIME | See uhd::runtime_error.  |
| UHD_ERROR_ENVIRONMENT | |
| UHD_ERROR_SYSTEM | See uhd::system_error.  |
| UHD_ERROR_EXCEPT | See uhd::exception.  |
| UHD_ERROR_BOOSTEXCEPT | A boost::exception was thrown.  |
| UHD_ERROR_STDEXCEPT | A std::exception was thrown.  |
| UHD_ERROR_UNKNOWN | An unknown error was thrown.  |
| uhd_error uhd_get_last_error | ( | char * | error_out, |
| size_t | strbuffer_len | ||
Functions that do not take in UHD structs/handles will place any error strings into a buffer that can be queried with this function. Functions that do take in UHD structs/handles will place their error strings in both locations.
