uhd::stream_cmd_t Struct Reference
enum  stream_mode_t { STREAM_MODE_START_CONTINUOUS = int('a'), STREAM_MODE_STOP_CONTINUOUS = int('o'), STREAM_MODE_NUM_SAMPS_AND_DONE = int('d'), STREAM_MODE_NUM_SAMPS_AND_MORE = int('m') }
 stream_cmd_t (const stream_mode_t &stream_mode)
Public Attributes
enum uhd::stream_cmd_t::stream_mode_t stream_mode
size_t num_samps
bool stream_now
time_spec_t time_spec
Command struct for configuration and control of streaming:
A stream command defines how the device sends samples to the host. Streaming is controlled by submitting a stream command to the rx dsp. Granular control over what the device streams to the host can be achieved through submission of multiple (carefully-crafted) commands.
The mode parameter controls how streaming is issued to the device:
  • "Start continuous" tells the device to stream samples indefinitely.
  • "Stop continuous" tells the device to end continuous streaming.
  • "Num samps and done" tells the device to stream num samps and to not expect a future stream command for contiguous samples.
  • "Num samps and more" tells the device to stream num samps and to expect a future stream command for contiguous samples.
The stream now parameter controls when the stream begins. When true, the device will begin streaming ASAP. When false, the device will begin streaming at a time specified by time_spec.
◆ stream_mode_t
Enumerator
◆ stream_cmd_t()
uhd::stream_cmd_t::stream_cmd_t ( const stream_mode_t stream_mode)
◆ num_samps
size_t uhd::stream_cmd_t::num_samps
◆ stream_mode
enum uhd::stream_cmd_t::stream_mode_t uhd::stream_cmd_t::stream_mode
◆ stream_now
bool uhd::stream_cmd_t::stream_now
◆ time_spec
time_spec_t uhd::stream_cmd_t::time_spec
